HP Compaq 6710b won't turn on - battery is not dead, power cord won't work
  • 1 more comment
  • antwarby Jan 12, 2009
    I have exactly the same proble hp compaq 6710b Will not power up at all battery is fine and power charger is fine. Any suggestions would be much appreciated.
  • robertcollin Feb 01, 2009
    I have the same problem; I suspect the battery has failed?
  • Anonymous Feb 19, 2009
    I took out the broadband card and mine will boot up. But I need that.
3 Suggested Answers
info2u
  • 596 Answers
SOURCE: BLINKING POWER LIGHT
When you restart your notebook do you have a blinking cursor when the system freezes? It sounds like you need to reset your BIOS. To do this, power off then on your unit, Press F10 to enter BIOS settings, and then F9 to reset the BIOS to default settings. (Your functions may be a little different but you can read your menu to see which function key to select.) Once this done, select "Save and Exit BIOS" This should get you going. As for the blinking light, sometimes this happens when the battery is not holding a charge. If your battery is new, try the BIOS reset first and comment on your results. I can guide you through the battery reset process, if needed. Good Luck.
Posted on Feb 02, 2009
  • 125 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
Do you have another power cord to check? Most places like bestbuy is willing to let you test a universal power cord for your type of laptop before you buy. Usually in your case, the power cord or connector has gone bad. If you test the laptop at the store and it doesnt work then its your connector but if it works. you could consider buying that power cord.
Posted on May 07, 2009
Hp compaq 6710b is not powering when i put the powerpack
Does that mean it DOES power up without the battery?
Or by power pack do you mean the AC adapter?
Replace it. either way
Apr 09, 2014 | HP Compaq 6710b Notebook
Battery light flashes seven times
Does the computer function properly with the power cord plugged in? If not, that means you need a new power cord because it is not charging the battery. If the computer works with the power cord plugged in then return the battery. Just because it is new does not mean it is working.
Apr 28, 2012 | HP Hewlett Packard Compaq 6710b Notebook...
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
I have a HP Compaq 6710b. i can run the laptop from the mains power supply (240vt) no problems at all. the battery meter says that it is at 100% charge but when i pull the power cord out the laptop turns...
Try downloading the latest bios for the laptop, i had the same problem of windows reporting that the battery was fully charged when it was actually empty, a bios update fixed the problem
Mar 26, 2011 | HP Compaq 6710b Notebook
My HP Compaq 6710b was fine and then just died, what happened?
First,you should check wether the connected power or Compaq business notebooke 6710b battery is OK.If There are no problem ,then there maybe some strange matter !
Sep 23, 2009 | HP Hewlett Packard Compaq 6710b Notebook...
Computers & Internet Logo
1,598 people viewed this question
David Payne
David Payne
