Question about Whirlpool Calypso GVW9959K Top Load Washer
NO COLD WATER
I HAVE WATER COMING THROUGH THE HOSE BUT IT WILL NOT GO INTO THE MACHINE THAT IS ONLY THE COLD WATER BUT THE HOT WATER IS FINE. THE SCREEN IN THE MOUNT ON THE MACHINE IS FINE I EVEN REMOVED IT TO MAKE SURE. I SWITCHED HOT AND COLD HOSES AND IT IS NOT THE HOSE
  • 179 Answers
If you cleaned the screen in the valve of the washer and it still does not work then you need to replace the valve. the valve on the cold side probably has a piece of sediment in it not allowing it to open.
Posted on Dec 20, 2008
No cold water coming into machine
Follow the cold water line inside the washer where it connects to a 'Fill Valve' which is a valve/solenoid. Using an electrical test meter check the two wires at the solenoid for 110 volts when the machine is calling for cold water. If there is voltage but no cold water the valve is most likely bad. You may also want to pull the hose to make sure you have water running through the hose from the spigot. With the hose off at the valve look to see if there is a screen at the valve that might be clogged.
Dec 04, 2013 | Roper Washing Machines
No water is coming on at the start of the cycle
check hot & cold hose , take off hose from washer . Put in bucket open water coming or not .
Apr 18, 2017 | Amana ALW895 Top Load Washer
I have a Kenmore 500 series washing machine. The cold water just trickles out but the hot is fine. I have replaced the fill valve, but the problems persists. Any help would be appreciated.
Having replaced the valve i would suspect the cold water for what ever reason is not getting to the valve from the faucet..if you have not already done so remove cold water hose and see how much water is coming from it when its not connected to the washer. If your using the "aqua flow-flood stop" hoses thats going to be the problem..the internal stopper in the hose has failed and hardly no water coming through the hose.
GENE
Aug 28, 2011 | Kenmore 24422 Top Load Washer
Cold water not coming in. Hot wash is fine with hot water only. Cold or warm wash pulls no cold water. Water pressure is fine, no pipe kinks. Could inlet valve be stuck? Any other possibilities?
Hi just read your posting.Now have you removed the cold water hose from the machine end and checked to see if there is water coming from the hose?Do any fault codes appear on your machine when the cold water is not coming in?Have you or can you borrow an electrical test meter to test the coils of the valves to see if they are faulty?Please reply with additional information on these questions and I am sure I can help you rectify this fault.
Aug 10, 2010 | Fisher and Paykel IWL12 Top Load Washer
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Hot water will not enter machine. Screen filter is clean. Cold is OK.
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Feb 04, 2010 | GE WDSR2080D Top Load Washer
No cold water coming in, only hot. hose is fine.
check screen in washer machine-turn off cold water unscrew the cold hose that goes into washer-check to see if screen is clogged a small filter
Oct 19, 2009 | Kenmore Washing Machines
Hot water in washer comes out fine. Cold water is very slow coming out. It dribbles and takes forever to fill.
Clean inlet screen where hose attaches to machine. Water from water heater is generally "cleaner" as sediments have had a chance to settle out in the water heater. Cold water carries more stuff directly to the valve screen. Check also for kinked hose.
Aug 28, 2008 | Washing Machines
Only Hot Water is Coming Out
if it is a 2 fill hose machine then you have the hosesd connected the wrong way round. to check, put on rinse and this should be cold water coming in
Jul 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
32 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
