Question about Zanussi FLA1001W Front Load Washer
Door latch broken, clothes stuck inside!!
Hi there, I have a zanussi (I think it's a FL 413) and the door latch has broken (the plastic handle has cracked) but my clothes are stuck inside! Is there a way to get them out in the meantime before I have the latch/handle replaced? (I've taken the lid off and fished around, but to no avail)Please help!
  • Anonymous Mar 20, 2014
    plastic catch on door release mechanism broken, door will not stay shut
    President:
  • 1,462 Answers
Not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Posted on Apr 01, 2007
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
Microwave door alignment
test all this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Door wont open
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aSkJuabC
Jul 29, 2013 | Haier Microwave Ovens
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
My Tenants have broken the door release handle on this WD860 and I need to get the door open to remove the clothing and dismantloe the door for repair. How can I do this?
Remoove plug from socket, then remove top from machine I think on this model you will need to remove the small caps on side of the top. Then there are 2 screws to remove this will allow the lid to be removed. then you can normally reach inside to release the door.
Feb 25, 2011 | Hotpoint Ultima WF860 Front Load Washer
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Door won't unlatch or come open
Ford had a problem with the door handles not working properly. They are cheap plastic. If the exterior door handle is broken, you will need to drill out the rivets that hold it in, and then get the door open and the panel off. You have to disconnect the rod going to it. Then, remove the handle. If you don't want to drill again, I suggest replacing the rivets with a bolt and nut easily obtainable at your hardware store. I've found that a M7 bolt works very well. If you are having a problem with the interior door handle, it's the same problem. Remember to check your door latch because if your exterior handle is broken, then your latch isn't working properly. I got one at Ford for about 40 bucks.
Oct 04, 2008 | 1999 Ford Explorer
Zanussi FLA1001W Front Load Washer Logo
367 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
