Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Dell ultrasharp 15 inch flat panel lcd has no power and does not turn on at all
When I push the power button and nothing happens. What can that be. In there fuses I could check? Can some help me with Ideas? ALOHA
    Novelist:
  • 86 Answers
Disconnect the monitor from the computer, then turn it on. You should see three bands of color (red, green, and blue), which is the self-test feature of the monitor. If you can see all three colors, the monitor itself is probably OK, and it will mean that you need to check the connector on the monitor cable, the connector on the back of the videocard in the back of the computer, or reseat the videocard itself. One of the connectors could be damaged, or you could have a bent, broken, or missing pin within the connector. If a pin is bent and touching the shell of the connector, it can send the video signal to ground, making the monitor appear to be dead. BE VERY CAREFUL if you try to straighten the pin; they are fragile, and if you break the pin off completely, you will have even more problems to deal with... If one or two of the color bands are not visible, the LCD monitor is defective, and you'll have to decide whether it is cheaper to repair it, or simply to replace it... If you still can't locate the problem after checking the system as I've described, get another monitor to test the computer with. If the second monitor works properly, you most likely have a problem with the Dell LCD; if the problem still exists after switching monitors, then you most likely have a problem with the computer, and NOT with the Dell monitor...
Posted on Apr 01, 2007
SOURCE:
Dell 2007FPB LCD Won't turn on nothing happens when the power button is pressed
Hi and welcome to FixYa!
As a first course please check the monitor power cable. It may be a little loose that's why its not powering up.
Hope this helps and thank you for using FixYa!
Dec 02, 2010 | Dell UltraSharp 2007FP (Black) 20.1 inch...
Monitor problem
It sounds as if the backlights are failing. It is probably cheaper to replace the monitor than anything.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 18, 2018 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Power button doesn't work...
Your problem is not the switch. Probably you have faulty capacitors, deteriorated solder joints or worn out bulbs.
To open the case, remove the base (push button and lift off).
remove any screws under the base plate.
Pry the front and back cover apart, they snap together.
Good luck,
Monitor Mike
Oct 12, 2006 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
157 people viewed this question
Clive
Clive
Alun Cox
