Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell proheat 1698
The machine sprays and works fine but will not dispense solution. Belt is not broke.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
r43
Posted on Sep 30, 2010
I am pulling the trigger and the carpet solution won't spray out
too much cleaner in the mixture, do you see the little fan type thing in the window spin usually when you dispense cleaner well it won't spin and dispense cleaner if you get it too soapy or concentrated.
Jul 07, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698-p proheat powersteamer instruction manual
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 10, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Not spraying or picking up water
heatman101
bmv,
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell Power Steamer Proheat Plus not dispensing
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell proheat 1698 reassembly, smart mix piston, new pump?
heatman101
erqtr
Mar 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell not removing any water from carpet
there is a washer type of deal that goes between the water container and the vacuum. if it isnt there , ther is no suction.
my kids lost mine-------------
Aug 31, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
173 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
