The washeer machine give a error code E4
Hi there my name is Paul i have a trouble with a wash machine bosh
model# WFMC3200UC, give a error code E4 can you please tel me the problem. i'm waitting for your answer
thanks
Paul.g
Don't have the manual for sanyo washing maching asw f120at. Error code u4. Can someone give me plz
Posted on Feb 10, 2014
  • 8,197 Answers
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Posted on Dec 19, 2008
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
I have a ge profile washer and I get an e4 error code
Hello Lisa;
My name is Peter. I am a retired field service appliance technician.
You did not provide any information so I have to be general.
1.) I assume this is a clothes washer and not a dish washer?
2.) What is the model number? It should be on a label on the face of the unit after you open the door.
3.) The E4 error code on your model washer is an inlet valve failure. Does washer seem to fill up with hot and cold water at a steady rate?
Mar 20, 2015 | GE Washing Machines
Samsung trouble shooting
The E4 is an error code. What the washing machine "is trying to communicate" to you is that it has detected a load imbalance at the clothes being washed; thus it won't be able to spin at full speed. Maybe it stops waiting for you to distribute the clothes more evenly. See more about error codes at http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html.
Aug 28, 2014 | Washing Machines
Hi all, can you help me to solve this E4 problem for my washing machine HITACHI MODEL SF-T1120X
E4 is an unbalanced error- the load in the drum is unbalanced. Try switch off the power and re arrange or remove some of the items to be washed.
Jan 03, 2013 | Washing Machines
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
Washeer model KHWS01PWHO it does not seem to be spinning or pumping out water and the code is reading FO2 but drain hose is clear
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 13, 2010 | KitchenAid KHWS02R Front Load Washer
Whirlpool duet washeer has f33 code
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Washing Machines Logo
1,631 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
