Whirlpool calypso washer stops on spin cycle after about one minute
  • 179 Answers
It probably sprays a little bit of water then stops right? if so then there is something stuck in your pump or you need a new pump
Posted on Dec 20, 2008
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
After washer runs for a few minutes it stops and runs agains, stops and runs again with stop and start intervals getting shorter and never finishes cycle. Seems it's unable to spin continuously.
there are usualy sensors for the spin so that the drum is balanced properly if one of the sensors is faulty it will not spin or if the wate is not draining aswell so check the owners manual to see if there are any tests for he sensors that can be run to give you a code for the fault
Nov 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Never stops - time remaining doesn't change after 38 minutes
this sounds like a bad timer motor.this what determines the cycle time.
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Heelo, during the spin cycle the washer stops and
Water not draining from the tub. Check for hose crimp ir clog. Here is your manual codes on page 19.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso won't finish spin cycle
Error is Insufficient cycle!
first try to unplug the appliance for 5 minutes and then restart it and see if the system reset!
if not you need hands on service. Not every situation is easy.
Please let me know what happened?
Plese rate me at our site too, before you sign off!
Thank You for using our service!
Jul 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
