Question about iLO 3200 32 in. LCD Television
The tv do not work
Ilo mod lct 32ha36 no work 'there 3 capacitors bad 16v 1000yf something else. my proble is at power.
  • lusoc1 Dec 30, 2008
    3 capacitors 16volts ... 1000uf and is ok.
Poer supl. do no work: solusion 3 capacitors 16volts 1000uf . now is workink ok.
Posted on Dec 30, 2008
Hi i have a ilo 32" tv, it powers on for 1 second and then picture goes black and the power button continues on, how can i fix it?
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board.
Jun 12, 2011 | iLO 3200 32 in. LCD Television
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
Problem with Mitsubishi 52525 TV
A teady blinking green Led is usually caused by the foru 1000uf 16V capacitors on the DM pwb
May 24, 2009 | Mitsubishi WD-52528 52" Television
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
ILO LCT32HA36 will not power on
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Aug 24, 2008 | iLO LCT32HA36 Television
Ilo lct 42ha36
HI
YOU NEED VIDEO BOARD.
GEORGE
Apr 27, 2008 | iLO LCT32HA36 Television
Ilo lct27ha36
Apr 01, 2008 | Televison & Video
Wont start
Hi all. I came across this forum after "Googling" this particular model ilo TV. (LCT27HA36) Like a lot of you, mine would not turn on. It was just like lambon48's TV. Since I could not find an answer online, I took it upon myself to solve the problem. I am a retired radio engineer, and have experience in repairing a vast assortment of electronic equipment. The problem with my TV was isolated to the power supply board. I found several capacitors to have bulged. That is, the tops were swelled outward. This usually is a sure sign the capacitor is bad. The ones that were bad were all of the 1000 uf capacitors and one 470 uf capacitor. Now these caps were rated at 16 volts and 25 volts. When I replaced them, I used 35 volt rated capacitors. These caps can be bought at Radio Shack for about $1.60 each. It cost me $10.50 to fix my TV. I recommend you having only basic knowledge of soldering to do this. Just take your time and notate how the caps are installed before you remove them.. Please make sure you install the caps properly. That you put the positive and negative legs of the capacitor in the proper holes. If your board is like mine, the positive side is marked on the circuit board. If you are hesitant on soldering, I bet you know someone who can do this for you. Good luck.
Mar 21, 2008 | iLO 2600 Television
Akai LCT 32"
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
iLO 3200 32 in. LCD Television Logo
59 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
