Question about Bernina Bernette Deco 600
Tension problems I have had the machine checked but top of project has alot of loose looped stiches adjusted top tension with no change. tried different kinds of stablizer, tried it underneath and on top and both. does it possibly need a new race? Please help ready to put it the garbage
  • edfarmer62 Dec 20, 2008
    Thanks But I have done that tuned the screw out and turned it in and it still does that the, screw seems to move it;s self,right now thescrew is turned all the way in.
  • 19 Answers
"Thanks But I have done that tuned the screw out and turned it in and it still does that the, screw seems to move it;s self,right now thescrew is turned all the way in."
Often the spring on the side of all bobbin cases ball up with lint, this causes the spring to flex and let the thread pass under without any tension. Pull the spring off and clean the side of the bobbin case and the underside of the spring, your spring may also be warn and need to be replaced...
Posted on Jan 02, 2009
  • 202 Answers
Hi, loops on top are signs of a loose bottom tension. There can be a number of issues. First put in a new needle. The bobbin should be in turning clockwise. This is going to take a few tries before it starts looking right. Get a tiny screw driver. There is a small screw on the bobbincase that the bobbin sets in. You will need to turn that screw 1/4 of a turn at a time until the stitches tighten up and the problem disappears.
Or its possible your not getting the thread threaded through the bottom tension spring correctly.
Posted on Dec 20, 2008
  • Rick
    Rick Dec 20, 2008
    The manual suggests painting ( nail polish?) the screw when it gets right. Possibly the position of the rotary hook bracket is off. But I think the screw is not tighteng the spring anymore. I suppose next I would look into getting a new rotary hook from a Bernina tech if you can. I have a 600 .pdf service manual I can send if you think it will help make other adjustments..
    callnrick@yahoo.com
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
How can I fix the top stich
I like to adjust with 2 colors, then you know which is from the spool, and which one is from the bobbin.
Most bobbin shuttles have a small screw to adjust the tension.
It sounds like your upper thread is adjusted too tight, but only if the loops around it (from the bottom thread) are tight and small. If those loops around the top thread are loose, then you need to tighten the shuttle screw. ;)
I notice this happens to me if I change thread types, also if I sew different thickness of cloth on the same settings. I tend to adjust until the point of breaking thread, then loosen the top a teeny bit.
Sep 06, 2014 | Sewing Machines
Why is thread looping under fabric, looks great on top???
Tension is based on tightness of stich. Hold with two fingers and pull should only feel little resistance. Both top and bobbin tension should be eq
Aug 19, 2014 | Sewing Machines
Tension problems
Yes the covers come off all machines. That does not mean it is easy to do. Since the problem is not on every stitch I would check the tension by installing a size 80 needle put the presser foot down and pull on the thread towards the back at a 45 degree angle to the direction of sewing. The needle should bend about a 1/8 to 1.4 inch at normal tension. If the tension is steady it could possibly be other reasons that the loops are forming under the fabric. Such as a burr on the hook, or bobbin case, lint, or clearance between the positioning devices for the bobbin case. I made a video about tension problems that are not actually caused by tension.
I also did one on common repairs for a top load bobbin sewing machine.
Nov 17, 2013 | Singer One Plus Computerized Sewing...
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Feb 25, 2013 | Janome Memory Craft 9000 Computerized...
The stiches at the botton are loose,it sound good at sewing but somehow it still a real mess ,no matter how i tried all different adjustment in the control bottons..
Looping on the underside is an indication that your top thread is not under tension. So you need to check again on the top threading up and make sure the thread is seated into the tension discs. Always thread up with the pressure foot raised to open up the tension device. Make sure the thread goes into the tension device, to test, lower the pressure foot and pull on the thread downwards - it should feel firm and resist pulling. If you can't get any tension onto the top thread, then the tension device may be broken.
You should not need to adjust the bottom tension at all.
If a machine is set up correctly the top tension should only need finessing by half a number at the most.
Sep 24, 2011 | Singer 5050 Mechanical Sewing Machine
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Thread loops up on the bottom of my piece and then binds up the machine.
Make sure that the tread is fully between the tension disks. Hold the thread at the spool and when placing it through the tension assembly pull both ends firmly.
When you increase the tension, pull on the thread while the presser foot lift lever is down and see if it gets harder to pull. If not, the thread is not between the disks or the machine is malfunctioning and must go for repair.
Large loops on the bottom are almost always caused by little or no tension on top.
Nov 13, 2007 | White Sewing White 4400 Computerized...
Sewing Machines Logo
118 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
