Question about Fostex MR16HD/CD Digital Recorder
Fostex MR16 Power Switch
The power switch has partly pushed through into the interior of the case.
I need to get access to the interior to push it back or replace if broken.
I have removed the four screws which appear to secure the lid, and also the slider control buttons, but the cover cannot be removed although there is slight movement on one side.
Can anyone help?
3 Suggested Answers
JSPCEXPRESS
  • 178 Answers
SOURCE: Trouble with Fostex mr16 cd burner
hELLO CYNTHIA. Are you using the stock memory in the unit.
Posted on Feb 10, 2008
JSPCEXPRESS
  • 178 Answers
SOURCE: Fostex mr16
Let me check the specs on it. Where abouts are you located?
Posted on Feb 11, 2008
I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
Feb 14, 2012 | Fostex Mr16hd 16 Track Digital Recorder
My MR16 says HDD full- so I erased 12 songs and 10 wav files to free up space. No matter how much i erase it still says HDD full when i attempt to record. do i have to initialize and lose everything to...
I had the same problem. After some reasarch I found out that even if you erase a song the data is still on the recorder in "hidden files".
What you have to do is download the WAV manager software from Fostex.com, then copy all your files to your PC, reformat the hardrive on the Fostex, and copy the song files back on to the Fostex form your PC.
I know it's a pain in the ****, but I guess that's one reason this thing was so inexpensive.
I still am very happy with mine, but after 3 years of constant use in my case, some type of maintenence can be expected to happen.
Jan 01, 2011 | Fostex MR16HD/CD Digital Recorder
My Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Feb 27, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
It stays stuck on home screen.it was not plugged in to power protecter when the power turned off . My fostex vf-16 is a later model similiar to the mr16 model
Try going to the Fostex.com site and download the instruction book. It could be a small electrical fault inside the machine. If you've tried all then take it to a Fostex dealer and have the look at it. They're too expensive to play around with.
Good Luck
Sep 04, 2009 | Music
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I pushed the AVX bottom 3 times. The TV screen went off but the red light on. I realized I didn't pushed the off/on bottom and mistakenly pushed the AVX. I picked up my remote and turned the TV off. Now I...
hiii.....
If the power supply is supplying the main board with the correct amount of volts, your controller board or your on off switch panel is malfunctioning and needs to be replaced. If its the whole board your looking at a few hundred unless you can find the same tv with a broken screen and just swap parts.The on/off switch board is cheaper but you have to remove alot of interior parts to access and becomes a hastle.
thank u rate me!!!
May 24, 2009 | Hitachi Televison & Video
Power window
Here is an easy way to tell if the motor is the problem or the switch, turn on the ignition and the interior lights, push the window switch to raise direction and watch dome light, if it dims slightly the motor is bad, if not the switch, since it is stuck down it is most often the motor brushes are dirty, you will need to pull the door panel drill a minimum 3/8" holes in dimples (3) of door sheet metal to access the 3 bolts that hold the motor to the window regulator.
Aug 03, 2008 | 2002 Ford F250 Super Duty SuperCab
Fostex mr16
Feb 11, 2008 | Fostex MR16HD/CD Digital Recorder
Feb 10, 2008 | Fostex MR16HD/CD Digital Recorder
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
69 people viewed this question
Top Fostex Televison & Video Experts
Michael Galve
Michael Galve
pawnpower
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
