Question about Yahoo Messenger
I try to download yahoo messenger 9 and i tried yahoo messenger 8 i get file cancelled or interputed is there a way to fix this?
  • Anonymous Dec 21, 2008
    am also faceing the same problem
  • 238 Answers
Delete all your temporary files from C:\Documents and Settings\your document folder\Local Settings\temp folder. If temp folder has been hidden, Go to tools, click View tab then click the option button for Show hidden files and folders. If you had installed previous installation of a yahoo messenger, uninstall it and try reinstalling it.
Posted on Dec 21, 2008
My yahoo messenger is locked 81003003
HI.......................
it has errors
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...
You need to remove version 9 completely 1st to Get version 8 to work.
Use this method: Start,My PC, C drive, open Program files.Next open Yahoo file then Messenger file.Click on UNWISE to Un install messenger 9 completely. Do not just delete yahoo file as this can cause problems with other Yahoo programs.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym...
Your contacts list and messages are stored online and will be there when you return to 8.1 messenger.
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
http://www.download.com/Adobe-Flash-Play...
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect.
More help can be found here; http://www.freecreed.com/userid.html.
GOOD LUCK........................
Sep 22, 2011 | Yahoo Messenger
I cannot fully load my web cam. yahoo freeze ups , missing memory on yahoo
If you are using messenger9 you need to go back to 8.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either. Stick to 8.1 until they work out the Bugs. Including people using 8.1 trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it.
Download the newest 8.1 .
Thanks
Arnob
Apr 22, 2011 | Yahoo Mail
I was using Yahoo Messenger 9 then updated to 10. Once I updated the Yahoo Messenger User Id become disabled. I uninstalled the Yahoo Messenger then installed Yahoo Messenger 10 again, still got the same...
It seems that you tried to save your ID with Password to automatically login option, and by chance the id was empty, and it is mixed in Registry of your windows,
Step 1: Uninistall the yahoo messenger from your computer from control panel also remove yahoo browser services or toolbars installed
Step 2: Go to program files folder and delete yahoo messenger folder C:\program files\yahoo
Step 3: What you can do is to clear the registry entries of Yahoo messenger, Download C cleaner from the link below
Download Ccleaner
When download finishes, Install the ccleaner in you system, just run the setup file and follow on-screen instructions, to install, This program is basically for cleaning system temporary files and also has the addon to fix registry errors,
Installation Process:
2: Select I agree
3: Choose the options you required for your software
4: After the software installation is finished select to run the ccleaner bilalseham_10.jpg
5: Select Yes for cookie scan bilalseham_11.jpg
6: On main interface you will see Registry button in ccleaner software. Click on Registry
7: CLick on Analyze and it will scan all the registry for errors
8: It will now show you registry error files, Click on fix selected issues
9: now it will prompt you to backup registry, its a good thing to backup your registry incase if it gives you any error you can restore the registry later on
10: Save to the local drive or external media
11: After saving registry backup you will now see the screen to fix errors, (Error count will depend upon the softwares installed on your system. Select fix all selected issues
Restart your computer and install yahoo messenger again from the web, I hope it will not give you error any more,
If you require more assistance feel free to reply to this post!
thanks for contacting Fixya!
Regards, BA
Feb 05, 2011 | Yahoo Messenger
My IM window does not display...when i right-click on any of my contact and select Instant messaging...nothing happens...also I tried video call and voice call...nothing happens...and also there is no...
dear friend,
may happen that the yahoo messenger you are using is corrupt or some files are missing...try to download it from other site(softonic .com)
hope this will do
enjoy & cheers
Jan 15, 2011 | Yahoo Messenger
Everytime i try to send a file via yahoo instant mess. i get an error and then it stops sending it
Check your messenger client is up to date... Try to use messenger version 8 or 9 ... bugs are fully fixed for 8.I think if you try using 8 version it will help.
Thanks
Dec 07, 2009 | Yahoo Messenger
My Messenger ID is grayed out. Why?
The messenger version 10 still having too many bugs..and not fully fixed...please uninstall/unwise/remove it, try download and install the other version like 8 and 9....and before installing please delete the Yahoo folder from c:/program files/ ....Hope it will work....Thats all...Thanks for subscribing Fixya....Good Luck
Nov 14, 2009 | Yahoo Messenger
I have been trying to download yahoo 9 and 10 I have windows xp but I get file has been cancelled or interputed what can i do?
you have to download yahoo from another website. check this site. www.filehippo.com. this site offers all the free softwares that you want including latest version. (Yahoo 10.)
Nov 02, 2009 | Computers & Internet
Yahoo messenger error 81003016
HI welcome to fixya free solutions. you are getting this error because of connection error! try to go to messenger then connection preference, its on the top left of your yahoo messenger..choose connect directly to the internet then apply. mess 9 noted for this error.
Messenger "9" 1st version was in Beta (testing) form. The newest version is not, But it's not working well either.Try using 8.1 "the newest before 9", until they work out the Bugs. Including people using 8.1 or older versions trying to message ones with 9 or reverse they are having compatibility problems; like text not showing,pictures not showing.Chat rooms not found or opening. It shuts down on Vista users , not allowing people to log in.Web cams do not always work. Many things do not work or are missing that YM 8.1 has. It Seems for Vista users it is so buggy Yahoo is giving up on it and are no longer trying to fix it. http://www.ymessengerblog.com/blog/2008/…
You need to remove version 9 completely 1st to Get version 8 to work best.Left over files and fragments from using control panel to remove messenger can cause problems/conflicts with the new download.
Download the newest 8.1 here http://download.yahoo.com/dl/msgr8/us/ym…
And it works well with Vista.
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here.
http://www.download.com/Adobe-Flash-Play…
Some people are losing signal,things fade out, freezing up or getting disconnected . This can be caused my running low on virtual memory! You can increase your memory by going to start button, settings, control panel, system, advance tab, performance, advance tab, virtual memory, change it, make it 1500 kb or higher, In both boxes, click apply then ok . This applys for all instant messengers,MSN, Yahoo,skype ect. And yahoo games.
If none of these work for you then kindly do comment back to me.
Aug 05, 2009 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
Unable to download Yahoo messenger
i downloaded yahoo messanger but it fail to run pls. help me
May 30, 2008 | Computers & Internet
Yahoo Messenger Logo
56 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
