The door light stays on. the driver door switch is working as the fuel pump run if door is oppened. It must be one of the other doors. I opened door and found 5 wires, i asume 2 is door switch and other is central locking. Which colour is door switch wires so i can "short" them and determine witch door is at fault
Hi Louis, The courtesy light switch is wired as follows. Power goes to the light. The light is then grounded through either the switch on the light or via each of the door switches. The reason for the interior light to remain on is that one of the door switches is worn and grounding all the time. look for a broken switch or one which is rough when operating. Regards John
SOURCE: 2003 Jetta TDI - Door locks open fuel door
Look for a short in the wiring harness in the door. The wires from the door lead to the convenience module (controls the doors and windows and some other settings including remote fob) that is under the dash. It sounds like some wires are crossed. VWs are also notorious for having problems with window regulators. They make the windows go up and down and are in the doors. Something might have happen to that and it cause a short. VW just extended the warranty on the window regulators to seven years because of these problems so you should be able to take it to a dealer and not get charged (this is in the U.S. at least, don't know about the rest of the world). The extended warrranty was not limited to original owners but you might want to ask the service people about it first.
SOURCE: Audi A4 Y Reg 2001, Central locking
reset you computer, do this by removing the positive battery cable for 10 mins.
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
SOURCE: 1999 Audi A3 1.8T Electric Windows and Central Locking Won't work
will your passenger door open with the key and is it just one side that your windows are not working or both. if its just one side it might be your regulator motor in the door thats not working if its both it might be your central locking pump usually in the boot. however if both of them are working fine it could be that your key needs reprogrammed however i think the 1st 2 are more likely to be the problem.
SOURCE: my central locking is not working properly
it is more than likely the drivers door latch assembly
