Question about Whirlpool GHW9100L Front Load Washer
How to replace the door bellows seal ?
The front door bellows seal is broken ,would you please to help me how to replace it? i need to replace the bellow seal--please e-mail me the service manual on the GHW9100LW1.
thank you
gwasham@aristotle.net
  • 188 Answers
Unfortunately the service manual will not tell you how to replace the bellows.
Tilt the machine back to create more space between the front on the door and the outer drum. Remove the screws for the kickplate and remove the kickplate for easier access. Open the door and remove the spring clamp holding the bellows to the door opening lip. Push the bellows into the drum to get access to the outside/ rear of the bellows (where it connects to the drum). There you will find another clamp which you loosen/ remove with a socket. Some models have an overfill tube on the top of the bellows (remove it from the bellows). At this point you should be able to completely remove the bellows.
Align the new bellows to the outer tub. Attach and tighten the inner clamp (be careful not to over tighten and periodically check the bellows and clamp placement as you're tightening to make sure it doesn't slip off). Attach the overfill tube (if equipped). Lay the machine back to level and install the front of the bellows to the door opening lip. Re-install the spring clamp by starting at the top and working your way down both sides (may be easier with 2 pairs of hands). Be careful not to overstretch the spring on the clamp.
Test with a quick fill and let it agitate for a few minutes to ensure there are no leaks (be ready to hit cancel and have a few towels just in case it leaks). Re-install the kickplate, make sure machine is still leveled correctly by trying to rock it diagonally from the top. Enjoy clean clothes!
Posted on Feb 17, 2009
The lock mechanism is in the lock position with the door open. I think 7 yr. old with a screwdriver. I tried to pry up on the plastic piece but seems kinda week. From what I can see the way this machine is put together, it's going to be a day project in getting to this thing from the back. I still don't know if I can remedy the problem in doing so. Any suggestions!!!
Posted on Jul 21, 2011
I have a frontloading Kenmore washer purchased in 2003. The door will not close, and there is a wire ring that fell off. Can I fix this myself? It looks simple but I don't want to make the problem worse...
The wire ring you are referring to is called the front bellow clamp. This is the clamp the holds the bellow (door seal) in place. This may be causing the problem you are experiencing with the washer door not closing properly. The following link explains how to access and reinstall a door bellow and clamps:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
As long as the spring is still intact on the wire hoop and not broken, the clamp can still be used.
After UNPLUGGING the washer, skip down to step 12. This is explains how to reinstall the wire hoop. Just make sure the bellow seal fits snug all the way around the door perimeter. Then, fit the wire hoop into the groove around the seal. It helps if you have a second person hold it in place as you install it.
Overloading the washer is the most common cause of the front bellow clamp coming off. If there are too many articles in the washer, they can become lodged in the door area and pull on the bellow. Always follow your manufacturer's recommendations in the owner's manual for proper loading.
If the door still won't close properly, you may have a broken door latch mechanism. Check the latch pin on the door and the latch on the door facing and make sure they are still mechanically sound and not broken. If the latch needs replace, the following link explains how:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
May 01, 2010 | Washing Machines
Torn rubber gasket
The front door seal is referred to as the "bellow". They do wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
repairclinic.com
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Also DO NOT overload the washer. This can contribute to premature wear of the door bellow and cause rips and tears.
Apr 08, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The following link explains how to replace a door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Another method involves removing the washer top panel and working down through the top of the washer. The method I have described, offers the best open access, however. If you have questions along the way, please let me know. I hope you find this informaiton helpful.
May 11, 2009 | Whirlpool GHW9200L Front Load Washer
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
HELLO DANIEL1490,
NGFAM AT YOUR SERVICE!
IF IT IS 1 YEAR OLD ITS IN WARRANTY CALL THE COMPANY THAT MADE IT!! MOST SEALS ARE UNDER WARRANTY LONGER THEN 1 YEAR! ( 5 YEARS)
AND IF IT IS PAST THE WARRANTY BUY A FEW DAYS,WEEKS,OR MONTHS THEY WILL STILL GIVE YOU SATISFACTION IF YOU PERSIST!
ASK FOR A SUPERVISOR!!
I DEAL WITH THIS EVERYDAY AND YOU CAN USUALY GET THME TO REPAIR IT FOR FREE!
THE WATER WAS LEAKING FROM DAY ONE ONLY A DROP AND NOW IT IS GUSHING!
PUSH ALITTLE AND THEY WILL FIX IT FOR FREE!!
HAPPY TO HELP YOU WITH MY EXPERIENCE!
PS. CAN YOU PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF??THANK YOU
Aug 26, 2008 | Whirlpool GHW9400 Front Load Washer
you must remove the large front panel. if you can manage that the rest will become clear to you. dont forget to unscrew the door lock before befor removing the front panel. you will find three screws at the bottom of the front panel under the kick panel, remove them and the front panel will come off.
Aug 18, 2008 | Washing Machines
Door Bellows
ben it is very complex to replace
May 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
did hte rear clamp come off or just the front spring. assuming its just front spring.carefully reinstall the boot over the front lip assy . easy enough!!here comes the fun!! the spring itself goes to the bottom of the rim.So hang the wire over the top of bellow and feed into the lip evenly as you go down both sides as soon as you get your hands to the 9oclock and 3 oclock positon I then change grip on the spring (use the tips of my fingers palms facing front assy and strech whole pushing down and in. I used to find small spring style clamps would work great for holding the wire in place till it would "pop" into place. a third hand is also very useful to hold in place .
Mar 12, 2008 | Washing Machines
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
430 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
