Question about Ricoh Caplio R4 Digital Camera
Card protection seems to be stuck on
I can't take, or erase photos from my Ricoh R4.
I've tried to format the card but when I go to the setup and arrow down to 'format' it won't let me even select the 'format card' button, as I press it I get a msg saying "! card is write protected"
Even when I go to the PLBK STS and arrow down to 'PROTECT' it won't let me select as it keeps bringing up the "! card is write protected' message.
I read the whole user manual and it says how to protect and unprotect etc. but doesn't mention the error message which prevents me from selecting any button
  • mikeyk Apr 11, 2009
    I have exactly the same problem. Even using a new card does not solve the problem.
New cards are dirt cheap these days
Posted on Mar 08, 2009
How cani unlock my camera? i cant delete my pictures?
Erasing a memory card: when erasing a memory card, individual photos are deleted from their directories on the card. You can erase one or more user selected images at a time, or erase all images at one time. However, any images that you've selected to be "protected" through another menu option will not be removed during the erasure process.
Formatting a memory card: format a memory card sample menuFormatting, on the other hand, deletes all images from a memory card, even the ones that may have been protected. It recreates the file system including new directories and folders where images are saved on the card.
Unlike erasing, formatting improves the overall performance of a card.
Low level formatting: some digital cameras offer a low level format in addition to the standard format option. With a low level format, all data on the card is deleted. New directories and folders are also recreated during this process.
A low-level format of a high speed memory card helps ensure smooth continuous shooting at a constant interval. For optimal video performance, it's also recommended that a low level format be done sometime prior to recording.
In camera, not computer: though opinions vary, many recommend formatting a memory card in a digital camera, not via a computer. If you plan to use a memory card that was previously used in another camera, format the card in the new camera before taking any shots.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 02, 2011 | GE J1455 Digital Camera
How to unlock my camera,i cant delete pictures
Installed 16gb sd memory stick. took 1682 pics and the first 1000 "disappeared".How do I retrieve them?
Did you format the card in your camera before you started taking pictures? If not, that's why this happend as the file structure was not setup. But no sweat. First you'll need to recover your lost photos, and also save/backup all of your photos onto your computer. You'll likely need to use recovery software. Here's some very good freeware. Now AFTER you've saved all your photos onto your computer, format the card in your camera to rejuvenate it, and properly setup the file/folder structure to prevent this from happening again. Note that this will erase the card, so only do this after you've saved/recovered all the photos onto your computer.
Oct 15, 2011 | Canon PowerShot A470 Digital Camera
Camera caplio r5 i cant take any more photos because it is coming up car is write protected
Remove the memory card and move the little switch to unprotect, try again.
Apr 24, 2010 | Ricoh Caplio R4 Digital Camera
Not able to shoot photos. Card is not readable
It seems there is some problem with Memory Card, So, two option will be there:-
1 )Try to Format the memory card.
2) Replace /change new one.
Note:- Formatting the memory card erase all the data including protected images and other file types. So, once you formatted the memory card there is no way to restore them.
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Olympus FE-180 Digital Camera
Card write protected
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Apr 28, 2009 | Ricoh Caplio R4 Digital Camera
After trying to upload photos from my Olympus 1050 sw I now cannot use the camera to take photos. It simply says ´write protect´. When trying to view the pictures it says ´no picture´ when there is at...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 08, 2009 | Olympus Stylus / mju 1050 SW Digital...
I am facing "write protected" message on my camera display
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect error message and the card can be used again.
Jan 04, 2009 | Olympus Camedia C-720 Ultra Zoom Digital...
Write protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Dec 28, 2008 | Olympus FE-230 Digital Camera
My c450 Olympus digital has slipped into write protect. I can't take more photos or transfer them to my laptop. Help!
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Aug 14, 2008 | Olympus Cameras
Ricoh Caplio R4 Digital Camera Logo
125 people viewed this question
Top Ricoh Cameras Experts
Bill DeLisi
Bill DeLisi
Marvin
Marvin
pictureman4u
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
