Question about Sony Playstation 3 (PS3) Console
Blue ray disc on Ps3 does not look high definition
I have a Sharp Aquos 1080p that my Ps3 is connected to with an HDMI cable but when I put a BD movie the picture is blurry, Regular movies look allot better. Games on my TV look awesome It's just the BD movies that look terrible. I looked at other peoples problems and ive tried to mess with the settings but no luck. Hope someone can help.
If your TV has a 120 mhz setting, turn it off. My blu-rays (and some regular DVDs) were having problems as well, but this solved it. Basically, the 120 mhz setting is just too good, even for a PS3.
The setting may have other names, but whatever it's called on your TV, it's responsible for providing extra scaling/processing from the source (your PS3).
Also, make sure your PS3 is NOT set to double-scale. "Normal" is just fine.
Posted on Dec 28, 2008
My Sharp Aquos BD-24 Disc Player has been working awesome (for all my dvd's, including bluray) since I first installed it over a year ago. This week I've tried 3-4 dvd's including bluray and the picture...
Its highly likely a cable issue. You know which cable connection is wrong if are using component in and out. But change to a new connection cable whatever it is and I think it will be solved
Mar 08, 2014 | Sharp AQUOS Blu-ray Disc Player
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Hi...I also have a Sharp BD-HP24U. My problem is When I load the new expendables disc, it only seems to load the scull and wings logo of the movie about 3/4 of the way across from left to right then stops....
I had this exact same problem with the Expendables. I have a Sharp BD-HP22U. I found this fix on another site regarding another movie. I thought it was a long shot, but gave it a try anyway....and it worked. Here's what to do: Turn off whichever device (TV or Receiver) your HDMI cable is going into - turn on Blu-Ray player, load Blu-Ray disc and then turn on the other device. Hope this works for you.
Hope this helps folks. :)
Dec 03, 2010 | Sharp AQUOS Blu-ray Disc Player
I have a sharp aquos bd-16u blue ray player, I get the audio signals but I'm not getting any video signal with the component output. My tv does not have hdmi inputs but it does have component inputs. What...
1. could be the cable you using.
2. Could be you in the wroung input
3. RaRE but it could be the Blue ray itself
You might want to try new cables the R,G,B ones..
Yiou can try it on another tv to see if that works.
in rare instances you could have a dead on arrival there,
Thanks I hope this helps please do be considerate and leave postive feedback and ratings.
May 30, 2010 | Sharp AQUOS Blu-ray Disc Player
My ps3 iant reading games or blu ray discs how can i fix this myself?
I've been told that Blue Ray movies don't work on PS3 unless you use an HDMI cable; but I haven't tested that. Also, some Blue-ray on PS3 load as movies, some load as games depending on the content. So check the automatic play feature, see if you can select the BD from the video section. On your Xross media bar, go to videos and see if there is a blue disc (BD-rom), click X.
Also make sure that the movie is actually blue-ray. Some old HD movies are sold off on eBay, etc as Blue ray when they aren't. Check it on Blueray.com, if the movie isn't listed it may be HD only.
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
How can I get my bought today ps3 to play a blue ray movie? It isn't even 12 hours old. I put the movie in and I get nothing. Please help me.
You may, need to update over the internet for that to work, properly. Also try this go to BD/DVD Settings, then BD 1080P 24Hz Output (HDMI) and changed the setting from "automatic" to "off"... Then try & replay the movie.
Feb 16, 2010 | Video Game Consoles & Games
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Dec 25, 2008 | Televison & Video
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
158 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
