Question about Pantech Duo Smartphone
Just got an exchanged pantech duo
Still having charging issues with a new phone and battery.They did not send a new charger though. Now it drains in a day. Still has issues charging too. Also not sending texts and not showing incoming calls just got it 2 days ago. Works worse then the old one!!!
  • Anonymous Dec 21, 2008
    I have had 3 Pantech Duos exchanged...and having the same problem everytime. The phone is indicating that it's fully charged and within 3 hours completely dead
The issue may not be your phone or the battery. It may be the charger. My friend and i both have a pantech duo. She was always having problems with her battery, draining just after two hours. The funny thing was that whenever she used my charger, the battery kept charge. I tried my phone out on her charge, and found that it didn't keep the charge either. So we went to the store and found that it wasn't the phone, it was the charger.  Often the charger can mess up the phone. Order a new charger, and that should be the solution to your phone. (:
Posted on Dec 20, 2008
My daughters new phone Pantech Ease P2020 (bought 4 months ago) is not keeping a charge for very long. We are in a strong signal area (Deerfield, IL 60015) and she makes phone calls rarely (1-2 times a...
Unfortunately, as I myself have discovered, the battery lifeof Pantech Ease is not up to par even for light use. I bought a beautiful used Pantech Ease on-line from Mobile Karmafor 50 dollars and the (used) battery that came with it was verydisappointing. They very promptly sentme another Pantech battery that is about the same as the other one. I had to charge them twice a day unless Iused ATT Navigator GPS, which needed a recharge after only using it for a 20minute drive. Anytime you use a 3Gnetwork for ANY kind of data the drain on the battery is tremendous. The touch screen is also a drain; it isbetter to enter information on the slide out keyboard. Using Bluetooth is also a big drain on thebattery life.I have a background in electricity and electronics and havea good understand on the proper use, charging and maintenance ofbatteries. However, for me, theLithium-Ion is a critter that I was unfamiliar with. Therefore, I turned to the best and most highly technical sourceof battery information I know of and read an article and great discussion foundat battery university.com called "charging lithium ionbatteries" - This is a summary of what I learned there:Li-Ion Batteries do not have a memory like some other typesof batteries, which is a good thing. Therefore there is no advantage to completely discharging thebattery. In fact, it is notrecommended. Luckily there is normallya battery monitoring circuit in the phone that prevents a "complete"discharge of a battery. If these batterieswere ever completely discharged they would not be able to accept a charge froma standard charger. The use of specialcharging equipment would be required to hopefully "revive" thebattery.The best practice for charging and maintaining Li-Ion batteriesis very similar to that of Deep-Cycle batteries. It is best not to drain the battery completely. If the indicator on the phone shows one barremaining, that would be the best time to recharge. Changing through the USB port of a computer is best because it isa slower trickle charge. Most otherchargers are a fast charge. A fastcharge means more heat and heat is an enemy of these batteries. Heat is another reason why it is best torecharge the battery with the phone turned off. When the phone is on it generates a fair amount of heat, whichadds to the heat generated by the charging process. Last but not least to not over-charge or charge for a prolongedperiod of time. The phone notifies youwhen the battery is fully charged even when the phone is off. I have tested, with the phone turned off,and I find the battery does get noticeably warmer if the charger remainsconnected after the battery is shown to be fully charged. Remember, heat is the enemy.If I try do use the phone intensely (i.e. surfing theinternet) when the phone is down to one bar and I have the charger hooked up Iwill soon start receiving notifications from the phone to "CheckBattery". What is happening is I'mdrawing more power from the battery then the charger is able to supply (evenwith the fast charger) and the battery power/charge monitor in the phonenotices the battery is not accepting any charge, which is true. Normally that would mean that battery is badbecause it is not receiving or accepting the power being supplied by thecharger. But in the situation describedI am using more power from the battery then the charger is able toreplace. This is a bad situation. There's a yo-yo effect going on with thebattery at a low state of charge. Again, this situation causes a lot of heat, the enemy.Bottom line, the Pantech Ease battery is not adequate. It is only a 1000mAh at 3.7Wh and shouldhave been at least a 1500mAh at 5Wh. No one makes an extendedbattery for the Pantech Ease so we are stuck with what we have. With both used batteries I have, aftercharging them consistently as described above, I'm getting twice the standbyand talk time from them then when I first received them. However, when I use the GPS I can count ondraining the battery very quickly.My solution has been to purchase a Portable Power Kitmarketed by Energizer that includes a battery that is rated 1000mAh at4Wh. Physically the battery is twice aslarge as the Pantech battery. I boughtit at Walgreen's for $29 dollars. Itcomes in a small zippered case and includes a USB car charger, an AC travelcharger that trickles at only 0.1A (compared with the Pantech AC fast chargerthat puts out 5 times the power), a USB car charger and an 3-way adapter cablethat lets you charge your phone AND the backup battery at the same time. I use the phones' GPS in the car with thephone in a cradle attached to the A/C vent of the car. It is summer now so cold air blows directlyon the phone while the Energizer car charger via the small cable maintains thephone while I'm using the GPS. There'sdefinitely no heat buildup in the battery when I charge this way.The same small cable also allows me to charge the phone fromthe Energizer battery directly. No needto open up the phone and swap out any batteries. Some people carry an extra Pantech Battery but that can be riskybecause the battery contacts are exposed and it's easy to short the batteryagainst something metal (Not Good). You're looking at a dangerous amount ofheat in less than a N.Y. minute.The Energizer battery is as thin as the Pantech battery sois slides easily in the back of the phone case I wear on my belt. I can even use the same cable to charge thephone directly from the Energizer battery while they are both in that phonecase. It doesn't have any exposedcontacts; it has a recessed micro USB connector just like the phone. The Energizer Kit with both chargers,external battery power pack, cables and connectors costs less than any other qualityexternal power pack I have seen and the other power packs are too big to beportable in the same practical way.I'm sure this is way more information than you were lookingfor but as I searched for a solution to this problem I discovered how manyother people are so disappointed with the battery life of the Pantech Ease andalso searching for practical solutions. I sincerely hope this solution is of help to you and to others.
Sep 23, 2011 | Pantech Ease P2020 AT&T
My phone wont turn on.
maybe you need a new battery
Apr 05, 2010 | Pantech Duo Smartphone
Pantech C810/Duo Power Problem
YOU MIGHT WANT TO REPLACE THE BATTERY THE LIFE MAY BE GONE CAUSING IT TO NO LONGER CHARGE
Aug 31, 2009 | Pantech Duo Smartphone
Charging error
something is either wrong with your charger or your battery is possibly shorted inside.
I would buy a new battery and try it.
However, if you have a warranty on your phone i would exercise that and at least go talk to you dealer about it. whats the worst that can happen.
after looking in the net, this phone apparently has an issue with a charging error, so use that as you reason. Tell them your afraid it may cause a fire.
Jun 06, 2009 | Pantech Duo Smartphone
Saving pictures on a pantech duo
Yes, if you want to transfer pictures, music, etc to your new phone you will need to purchase a micro SD card. Make sure it is 2 gig or smaller though, as the Pantech Duo will not read anything larger.
May 08, 2009 | Pantech Duo Smartphone
Pantech Duo. Phone stuck on "At&t" and can't restart. other options?
mine did this to i plugged it into the charger then put the battery back in and it worked then i had to master clear and it stopped causing doing that though it still restarts on its own sometimes.
Apr 19, 2009 | Lands Phones
Talking on my pantech duo without the battery.
i had the same problem. I bought a new one from www.pantechbattery.com seems to have worked so far....
Apr 08, 2009 | Pantech Duo Smartphone
Pantech Duo will not charge.
Well its not that bad, all you can do though is take your phone to a mobile phone repair personel and tell them the situation with your pantech and they will have it fixed and working perfect in no time
Apr 04, 2009 | Pantech Duo Smartphone
Pantech Duo Won't Charge
go to any cell-phone dealer and ask for a replacement battery for your model pantech
Mar 22, 2009 | Pantech Duo Smartphone
Pantech duo won't charge or turn on
If you have the USB cord, trying using that to charge it instead. I had this same problem and it worked. Once the phone gets some battery, stick in the charger and resume charging on that. hope this helps!
Nov 10, 2008 | Lands Phones
Pantech Duo Smartphone Logo
151 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
