Question about AT&T Computers & Internet
I cannot access my LAN from my newly installed Network Adapter.
I have a LAN with 4 hard wired devices connected to it (three workstations and one networked printer). I wanted to free up one of the hard wire ports on my AT&T router so I purchased a Dynex USB Network Adapter and installed it. I have no problem accessing the internet but I no longer can see any of the other computers or the printer on the Local Area Network.
  • kroupa57 Dec 26, 2008
    Thanks for all the suggestions on how to resolve my problem of my computers not seeing each other on my LAN. I finally resolved the problem - it turned out to be that the networked printer had grabbed the same IP address that had been assigned to one of my workstations. So I accessed the IP address on the workstation and changed the IP address to resolve the duplicate IP addresses. Thanks again for helping me think deeper into this problem and get it resolved.
  • 55 Answers
Check for any firewall that were installed with the new NIC card. Also ensure that you are still on the same network as your printers and other devices. You can check the IP address of your computer by opening a command prompt and typing ipconfig. To open a command prompt click start and then run. Then type cmd. Do this both on your computer that can not see the printer and other devices and from one of the computers that can see the printer. The IP's should be similar. For example they should both start with 192.168.xxx.xxx or 10.xxx.xxx.xxx.
Posted on Dec 20, 2008
  • Christian Goforth
    Christian Goforth Dec 26, 2008
    I am very happy it all worked out for you. If I can be of any further assistance please let me know.
Driver for wis12abgnx/xec
Assuming you can get the driver (which comes as a file, i.e. software, not hardware) how would you install it on your TV ?
According to the 'Technical Information' link on the Web page that you can access via the link I attached with my answer, your adapter is compatible with WiFi-ready Samsung TVs and AV equipment produced between 2010 and 2012. If your TV is not a WiFi-ready Samsung TV or is one produced before 2010, well....If it is a Samsung TV produced after 2012, it probably has WiFI built-in, in which case you don't need any wireless LAN adapter, Samsung or otherwise and the TV did not recognize the adapter because the USB port on the TV that you plugged the adapter in is meant to be used for other devices, e.g. flash drives or portable hard drives.
SAMSUNG WIS12ABGNX XEC Wireless LAN Adapter 3D Accessories pc
Aug 30, 2014 | Samsung WIRELESS LAN ADAPTER...
No connections are available windows 7 but computer connected with network as well.
Boot the machine at first. If the problem still remains, make sure you have installed latest network card drivers from manufacturors site. You can also try to disable the network interface card, then enable it.
Aug 14, 2012 | Dell Precisions Workstations T1600...
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Jul 09, 2011 | Computers & Internet
I am unable to access the internet connection on my system as some Adapter is not recognised by the system. Please tell me what is it
first you have to check whether the LAN drivers are installed properly to find whether LAN card is installed properly right click my computer then properties then hard ware then device manager then in network adapters do you see a circle with yellow color uninstall and reinstall the LAN driver then restart your system then click start run and type cmd and click enter then type ipconfig /release after ipconfig is release type ip config /renew then type ping 192.168.0 1 you will see the files pinging it means the computer is connected the modem if not pinging go to network connection in your control panel then right click you default device then click networking then select internet protocol and click properties make sure obtain an ip address and dns is marked if not mark them then save and exit
Apr 28, 2011 | Gigabyte Computers & Internet
Acer aspire 4740 having problem during connect internet by lan
note down your ip,and uninstall your lan card from computer management ->device manager and scan for hardware changes.
Mar 02, 2011 | Computers & Internet
Belkin Surf Network Adapter installed on my desktop connects to my wireless network and looks to be working ie. wireless icon in lower right hand corner is flashing blue with no red cross etc. However, I...
I got your issue , for your issue , I f you want to go online hard wired to the router , make sure the Local are connection in the comp is enabled as well you have coted that u can see red cross in the wireless network connection icon, so make sure do not have any preferred networks in the comp.
Thanks,
Prema
Sep 27, 2010 | Belkin F5D4070 Network Adapter
Second computer connected to this model gives message "Network cable unplugged" when it is not! network connection intermittent. What can we do please?
Hi Jackie!
It sounds like a communication problem between the router and the computer. Try the following solutions to solve this:
1.Connect the LAN cable to other free LAN port in the router.
2. Try using a different LAN cable.
3. a. Open Device Manager
b. Go to Network adapters. Click on the "+" sign next to it.
c. Double-click on your network adapter.
d. On Advanced tab, look for Speed/duplex settings (or Media Type)
and change it's value to Full autonegotiation (or AutoSelect).
e. Click OK on all windows.
f. Close the Device Manager and restart your computer.
4. Reinstall or update your network adapter device drivers.
A "workaround" solution - use a wireless network adapter to connect wirelessly to the router.
Hope I helped,
Pelu.
Mar 16, 2010 | Belkin F5D7630uk4A Wireless Router
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Network Card
Yes the network card is the same ethernet card. If your intel pro/100 is onboard try to re install the driver from the motherboard drvier. Check also in the manager device it the network device have a complex to the other device. Follow this, Click START then RUN type DEVMMGMT.MSC then enter check if the network adapter have a yellow question mark. If you found the network adapter right click and uninstall it.and click the ACTION and click SCAN FOR HARDWARE CHANGES. After the installation finished try to connect to the internet. If still the same even you input the correct ip in the network configuration. Buy a new LAN card it's not expensive, because usually the onboard lan is easy to damage or not working properly you can installed and configured it but you cannot connect to the internet.
Apr 15, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Computers & Internet Logo
156 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
