Question about Epson LQ-2090 Matrix Printer
Setting Character table (PC MC) On Epson LQ-2090
I'm trying to set printing language (PC MC) from the printer's Control Panel without connecting the printer to the computer:
From Reference Guide-> Control Panel->"Changing default settings" (On page 124) I fallow these steps
1. Make Sure Paper is Loaded/ Paper is Loaded (OK)
2. Press the Menu (Pitch and Tear Off/Bin) buttons until the printer beep once and the
    Menu lights (Both the Tear Off/Bin lights) turn on. / I Press the set button, the printer beebs once and the Tear Off/Bin lights are ON and they are blinking.
   The printer enters the default-setting mode and prints a message prompting you to select...../ But nothing happens ???!!!
Maybe I'm doing something wrong-please can You help me on this?
Thanks,
Regards,
Sadat
Employment Agency-IT Support
SOURCE: PROBLEME OF MY EPSON LQ 2090
je veut voire les composants du imprimante epson lq2090
Posted on Mar 03, 2008
alvinbga
  • 130 Answers
SOURCE: Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Posted on Jun 19, 2008
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
What setting to do , if i insert thick paper or plastic sheet to be printed
make and model of machine please? it depends on if you are printing or copying to the special media. there are settings on the control panel as well as in the print driver to select special media types. beware of "plastic sheets" and any coated paper if you are using a laser device that has a fusing unit that heats the media to fuse the toner. using the wrong media can cause major damage.
Feb 06, 2016 | Epson Dot Matrix LQ-2090 Printer
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
Print Traditional Chinese Characters
Try to find the characters in internet and then print them using pdf document oor any type.
The following links give you few Chinese characters.
Chinese character cards 1
Chinese character cards 2
Chinese character cards 3
Chinese character cards 4
Cheers!
May 06, 2013 | Epson LQ-2090 Matrix Printer
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Printer Epson LQ 2090 ask to insert paper for every pages
Please take note of the paper used. Letter Size A4 or custom. This can be set on the PC (Mac or Window). If not you may just reset the hardware by holding the 1st and 3rd button and then power on. You may hear a beep sound after resetting. Good luck
Sep 02, 2009 | Epson LQ-2090 Matrix Printer
How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
May 19, 2009 | Epson LQ-2090 Matrix Printer
Epson LQ-2090 Matrix Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
