Question about Philips Magnavox Learning Universal Remote
The directions say press the code search button. what is this?
  • roncold Dec 19, 2008
    i have not got it yet . the # on the remote is 20c103-1 i tryed to follow your directions and i can't figure it out....the big dummmmmy
  • 155 Answers
There is an image on the lower right hand side of this page in the manual that shows you where it is.
http://www.fixya.com/support/p220062-philips_magnavox_learning_universal/manual-18940/page-3
Posted on Dec 19, 2008
  • Lauren Chang Jan 08, 2009
    Just in case, here is the specific picture I was talking about. The line on the left is pointint to the code search button:
    Searching for Philips 20c1031 is not leading me anywhere. Are you sure your remote is a Philips? According to this site:http://www.urc.philips.com/ all of the American market Philips Universal Remotes start with either GVU, MRU, SED, SRC, SRM, SRU, or US2. If your remote is a Philips, hopefully a look around will lead you to a model number starting with one of those.
    If your remote isn't a Philips after all, let me know what it is and I will try to locate that button for you.
How do i search for tv code on remote
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
This is the general procedure for code search. If you wish to know more about code search and setup codes to different remote controls, check this site.
Jan 24, 2013 | One For All URC-3021 Remote Control
How to do code search on my rca xy 2300 remote for tv side
Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Aug 24, 2012 | Televison & Video
How to use the remote to search the code
Code Search
Aug 02, 2012 | RCA Televison & Video
SRU4050 codes
It seems that there is no setup code for this Aiwa device, with this Philips universal remote control. Anyway, try a code search method. If there is a pretested code, this process will help you.
controlled.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Code search by Brand.
Lets you search for a code for a specific Brand within
the Code Library for a particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to be controlled.
indicator remains on, then release SETUP button.
4. Press and release the numeric button (0-9)
corresponding to desired Manufacturer (see table on
code list sheet). The red indicator blinks off once.
Note, pressing "0" performs a full library search same
as normal Code Search Method on previous page.
5. Press the CHANNEL UP button ((orPOWER or
PLAY (VCR only)) repeatedly until the device to be
off with each button press. If you accidentally
overshoot the code required, press the CHANNEL
DOWN button to backtrack through the library until
the device changes channel. Pressing CHANNEL
UP changes direction to forward again.
6. Press and release MUTE to install the code.
Brand Search Method entry is now complete.
Note: When all codes under a Brand have been searched
the red indicator flashes rapidly for 3 seconds.
Jul 24, 2012 | Philips SRU4050 Remote Control
Code search button
Code Search
Jul 07, 2012 | Televison & Video
Free list of codes for a magnavox mru3300
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
Dec 13, 2009 | Philips Televison & Video
I lost my code sheet and I need the code for a Symphonic TV
controlled.
SEARCH
button.
stored three digit number under that mode. Good Luck.
Nov 20, 2009 | Philips PM3S Remote Control
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
Need code for a dynex tv
The code for the dynex is not listed you will have to do a search:
Code Search (by Brand)
Brand within the Code Library for a
be controlled.
button until the red indicator remains
on, then release the CODE SEARCH
button.
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
POWER or PLAY (VCR only))
the code.
Note, when all codes under a Brand
have been searched the red indicator
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
listed, try doing a device search of the
the steps below.
button.
then stays lit.
the code.
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
Entry and press Cable in step 2 of
Brand Search or Complete Search.
Jan 12, 2009 | Philips PM3S Remote Control
Philips Magnavox Learning Universal Remote Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
