Question about Sony Ericsson P990i Cellular Phone
Radio not working
My p990i cant receive FM radio signals.
  • Anonymous Jan 16, 2009
    FM not working
  • 1,800 Answers
Are u using the earpiece??
its like the antenna
Posted on Dec 19, 2008
I have a nexxtech am/fm/radio reciever model 1219178.I cant get any radio stations am or fm.was working fine in living room. now by window in basement.what can I do to get stations again?
Radios receive their signals from the airwaves. Since most homes are frame construction and have quite a few windows, radio signals tend to do well in first floor and higher settings. In high-rises, condos, and basements, where masonry construction is prevalent, signals are weaker or non-existent. If the radio has the ability to attach an antenna, you could use a dipole and fasten it up near or to the window to attempt to get better signal. This will or should help with the FM, but AM in that location is almost impossible. If the dipole doesn't work, there are outdoor antennas and there are some amplifier antennas that are available, but this increases cost.
Nov 20, 2015 | NexxTech Audio Players & Recorders
Hi i cant seem to get a proper working radio signal on my renault megane dynamique not sure what to do thanks
If the radio is new take it back it has a bad signal rectifier if its been working well but just started to play up have the antenna checked or replaced failing that your deck has worn out its rectifier if am or MHz am is as bad as fm then replace deck 10_3_2013_2_13_47_am.png
Sep 29, 2013 | Car Audio & Video
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
NO FM RADIO...
try changing the headset bec that it also your antenna.
Jun 12, 2008 | Sony Ericsson P990i Cellular Phone
No Signal After Reconnecting Roady2
Try playing the Roady 2 through a fm radio with the audio jack(middle connection) disconnected and the FM Frequency & Fm Radio set to the same station. At least this will tell if the receiver is working. I suspect that you got an aftermarket audiojack for your stereo. Might want to check that. Go back to the manual FM Modulation setup instructions. Any FM receiver will work. Good Luck
Oct 21, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Sony Ericsson P990i Cellular Phone Logo
44 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
