Question about Canon i860 InkJet Photo Printer
Problem with Printer Colour
I have a Canon i860 and I am having a problem with the colour. Everything is coming out green. I have all current inks in the printer. Help!
  • rhattem666 Dec 28, 2008
    I'm having basically the same problem. When I print photos everything in the picture that is red prints perfectly. Actual greens also print fine. The problem is with the faces. They all have this green tint to them. I've run the print head clean and deep clean. The alignment and the nozzle check. No improvement. Help!
Hi, my name is Robert R. in Edgewood, NM and I have been trying to fix this exact same problem on my Canon i860 for the last 7 hours. Finally, I did!
First let me tell you some essentials you will need:
A large towel that you won't mind ruining
A bottle of alcohol
An eye dropper
Some cotton swabs
Some canned air
Rubber gloves
Remove the ink cartridges and then remove the printer head.
Place 3-4 drops of alcohol on each of the ink pads and then place a couple of drops of alcohol on the printer head. Let it soak for a minute and then blow air through each of the ink pads. Dry with the cotton swabs and the repeat the whole process several times until no more ink comes out when you blow through the ink pads. When you are sure that you have accomplished this make sure to dry everything with cotton swabs.
Put everything back in the printer. Run the printers cleaning operation and then test. If you did it correctly all of the colors will be back. Before I did this, all I had was black and green. Now I have all colors.
BEWARE: This is a messy operation. I didn't realize it would be and now I have ink all over my hands and work table. It will take me another hour to clean up but you can avoid this by using the large towel and rubber gloves.
Good Luck, it should work!
Robert R.
Edgewood, NM
Posted on Dec 31, 2008
  • 3 Answers
Hi, My name is Eram, I want to help you with this problem. First, be sure this cartridge is new, because if the cartridge its passed of the manufacturing date, it won't work properly. Secondly, if the cartridge its brand new, might be that you need to perform some printer alignment. You need then go to all programs then your program named Canon printer, then Settings and then align your printer. You also may try to print a test page. If still showing only the green color, you have to procede to re-install your printer, might be that some software conflict is happening.
Posted on Dec 19, 2008
My Canon I860 has stopped printing any of the colors. When printing a color picture, the printing takes an extra long time and then only the black colors are printed.
To solve the problem follow the mentioned stages bellow:
1.Click start, then printer and fax icon
2.click maintenance tab, then clic ink cartridge setting
3. Select auto dedection or Black and colour cartridge.
Then cloge all.
Thank you.
Aug 27, 2010 | Canon i860 InkJet Photo Printer
Colors are off. Browns print green or purple. I
BROWN is made by mixing two of the three "primary" colours.
So, if the printer is out of RED ink, you'll get the "other" primary colour.
Print a "test" page, and verify that part of that page is RED.
Run a printer "cleaning" cycle, and consider replacing the RED cartridge.
Jan 08, 2010 | Canon i860 InkJet Photo Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Too much green
Printing too green is a sign of low or no Magenta ink. Might pay to look there. (Green is Cyan and Yellow ink, so Magenta is missing to make Grey/Black)
Sounds like someone might have also managed to mix up an ink cartridge and put it in the wrong slot?
Check that the nozzle patterns for each colour are in the right place on the print out according to the sample in the manual / online. Maybe Magenta is missing altogether?
Apr 21, 2009 | Canon i860 InkJet Photo Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
HI, I have a Canon IP4300. The image colour looks great on computer but when I print a paper print, the colour comes out exagerated so everything is over-bright and gaudy. How can I adjust the colour...
Assuming that your printer drivers have been loaded correctly to your computer it is likely that the ink cartidges are the cause of the problem. They are either dirty or low on ink (a particular colour if you have multiple cartridges). Have you tried someone else's printer perhaps?
Apr 27, 2008 | Cameras
Canon i860
Have a look at the yellow cartridge. I have had trouble with inks leaking into each other...most noticeable in the yellow. I have no solution...perhaps the printhead is a piece of ****...works well when it works.
Mar 12, 2008 | Canon i860 InkJet Photo Printer
Canon i860
Print head temperature rise [5200]
I would assume that the cleaning efforts resulted in oveheating the print heads.
Please ensure that you have sufficient ink, as ink acts as a lubricant for the heads.If you try to use them while empty it is equivalent to driving a car without oil.
Take your time..
Verify ink is in all cartridges.
Remove paper jam
let the printer cool off (heads)
Chances are the head alignment is not necessary and you are low on one of the inks...
Try this test program (Page) to isolate low colors...
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Feb 10, 2008 | Canon i860 InkJet Photo Printer
Problems printing photos.
Verify when the print box comes up that monochrome (Greyscale) is not selected.
Jan 18, 2008 | Canon i860 InkJet Photo Printer
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
87 people viewed this question
old marine
old marine
