FixYa.com
Tags:
GE JVM1870 1100 Watts Microwave Oven
GE JVM1870 Runs, but won't heat up (by 6 users)
posted by aero_geek on Apr 01, 2007
Less than 3 yrs old; the microwave will turn on & run (normal sounds), but will not heat food (or boil water).
Comment by aero_geek, posted on Apr 02, 2007
I tried disconnecting & then reconnecting the magnetron in hope that I just had a bad connection. No such luck. I did see a larger in-line fuse near the magnetron. I'll try removing/replacing it first. If it still won't work then I may need some further insight regarding the capacitor &/or the diode bleeder. Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by grandhi, posted on Jun 30, 2008
having a same kind of problem... is there any other solution which can help to solve this problem......
Comment by Guest, posted on May 17, 2008
i switched it on, then put in food to heat up. every sound was as the norm but when i openned the food was as cold as i put in. however, i noticed something unusual. there was a text reading 1s in the display area when you press the microwave button. i am just wondering what the 1s is actually doing there and just felt may be if that goes away my food will heat up. i have been trying but it is still there
Comment by Guest, posted on Feb 16, 2008
How do you get to the magnetron tube so we can replace it? I have the new part but need help getting to the old part.
Comment by Guest, posted on Nov 28, 2007
It Runs, but won't heat up
Comment by dnorment, posted on Nov 11, 2007
I have a Hotpoint over the counter Microwave Oven... 2+ years old... it  is not completely heating the food at normal temperatures.  I have tried finding the model number on the internet and without satisfactory results....  The model number is: REM25S-JO1....   anybody have any ideas what to do or who to talk to???
Best Solution
posted on Apr 10, 2007
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2679 votes
Gosh, things seem to fall apart here when I take a few days off! *grin*
On GE models, the most common "no heat" problems are a bad magnetron and a bad door switch.
Since yours in only 3 years old, the magnetron is still under warranty. Your being inside the unit will void that warranty if detected.
You should contact GE Customer Relations at
1-800-386-1215 (8-6 ET) to pursue warranty service.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 01, 2007
Helpful (85)
ice man
Rank:Wiz Wiz
Rating: 83%, 72 votes
most likely, there is a fuse that is blown. there is a big fuse that is connected from the high voltage capacitor with the power transformer secondary section. if you a tech person, you can do it on your own if not..do not even think about it..it is dangerous to open a microwave oven..now if you changed the fuse and still not heating, either the capacitor or the diode bleeder need to be changed.. good luck
Solution #3
Helpful (85)
snakehead
Rank:Wiz Wiz
Rating: 81%, 849 votes
your magnetron,high voltage capacitor or diode is bad takte it to a microwave tech for repairs.good luck.
Solution #4
posted on Mar 05, 2008
Not Rated (0)
boutros
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Our GE jvm1870 is now over 4 yrs old, and had been working fine-- until recently when using, didn't heat anymore & also started making a crazy sound.
Am no electrician, so I called GE to help. Needed a new magnetron & some diode. Part was under a 10 yr warranty- the total cost for service call + labor was under $200. Not great, but beats buying a new microwave ($400-700) and having to install it.
Solution #5
posted on Apr 09, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
continue with the solution. How do you test for whether it is the capacitor or the diode bleeder and how to replace the capacitor or the diodeand if this is feasible? cost and technical expertise.
This Problem Also Relates To: GE Spacemaker (JVM1640SJ) Microwave Oven GE JVM1440 950 Watts Microwave Oven GE JVM1850 1000 Watts Microwave Oven GE Advantium SCA1001SS 900 Watts Convection / Microwave Oven GE JE1590 1000 Watts Convection / Microwave Oven GE JE1640 Microwave Oven GE JE1660 Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
How does one reset the
How does one reset the Clock... Answer This...
Daewoo WM1010CC convection/...
2.5 year old convection... Answer This...
Magnetron
I call GE and they are sending... Answer This...
sudden power loss
It will not work for more then... Answer This...
Dirty Door Glass inside the...
Uncovered food splatters... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
