Question about Kenmore 43142 Front Load Washer
Kemore model 417 will not spin in any cycle. Water will drain
All doors are shut.
  • 121 Answers
Check pump filter
Posted on Feb 17, 2009
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Kenmore model 417 won't start, after doing one load successfully
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 29, 2012 | Kenmore Washing Machines
Filling with water then does not finish cycle
There should be a sensor on the door that tells it the door is shut. Check that this is being pressed when the door is shut. You should see it where the doormeets the washer and can use something to press it. Put your washing in spin cycle and press it if it starts spinning there is your problem( make sure the washer is empty ). If it still doesn't work you will most likely need a repairman.
Apr 18, 2012 | Candy Washing Machines
Kemore washer will not spin
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Jun 19, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Apr 29, 2007 | Crosley CW6000 Front Load Washer
Kenmore 43142 Front Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Robert Rankin
