Question about Blaupunkt IDC-A09 5-Disc CD Changer
2001 toyota tacoma blower works but no heat!
My 2001 toyota tacoma truck heater stopped blowing heat.  The blower still works though.
Help!
  • bkoczur Apr 13, 2009
    Same problem, (when I started the project) I found that one of the air diversion doors in the heater core airbox was stripped out, the link had broken clean off. That messed up the whole system for the other doors to work. I took the entire dash apart tonite, and will hopefully find another door in a junkyard this week. The old one came out without haveing to comepletly remove the heater core. The new one should go in with just as much swearing. But as I put the instrument cluster back on so I could drive to work, the tach, heat guage, and blower fan all crapped out. I can't find a fuse that covers all three. Anybody have a clue what I might have messed up? Any feedback would be great. bkoczur@hotmail.com
    Problem Solver:
  • 17 Answers
I had a diffrent problem. the water valve on the firewall was not opening when switched over to hot... the cable was not pushing or pulling. i took the control switch out (the knob that you turn for hot or cold) and took it apart. one of the sodier points off of that controle switch was cracked.. i just heated it back up and added a little sodier to it and whalllaaaaa works great but still trying to figure out why the blower motor doesnt work..... uhg
Posted on Sep 30, 2010
Ineed to be able to get my 2002 toyota tacoma out of the heat mode. Even when I shut down the blower fan abd turn the heat to cold istill get heat coning into the cab.
Hi do check the heater control valve and blower control module possible malfunction or faulty, Valve normally situated in engine bay . module will be found on internal heater box .
May 01, 2015 | 2002 Toyota Tacoma
I have a 1997 toyota tacoma that the heater works sometimes but not other times?
heater, totally dead.
1: blower working and blowing cold air ,
2: engine holds 180F or more all the time, HOLDS !! i use an IR pyro gun to do that as dash gauges suck.
3: heat lever bad, slipping or stuck (look)
4: some cars have no water valve, so use damper , it can stick closed.
if engine coolant was hot at heater failure we can work this easy.
yes< then is both heater hoses hot touch , fan on, engine hot.
see them as they enter fire wall, on both sides.?
you can in fact feel them on all cars.
ever do a real RAD cooling system flush , if not, BINGO, full of crap inside.
Dec 11, 2013 | 2007 Toyota Tacoma
2004 Toyota tacoma Pre runner 4 door AC works fine blows cold, No heat ? have checked radiator and thermostat as well as heater core have hot coolant running through entire system but still no heat not on...
You have a problem wit the air temperature control blend or the blend door actuator motor, most times both are defective. The parts are located deep in the dash and as such the dash assembly must be removed to service the parts.
Jun 26, 2017 | 2004 Toyota Tacoma
2006 tacoma heat/air blower fuse location
Hello! Coil of Heater Relay is supplied through Fuse "IG1 2" (10A)...Located in the Drivers Side Box...Contacts of Relay are supplied through "Heater Fuse (50A)...Located in Engine Relay Box...Blower Motor has a 2 wire connector with wire colors: Black/Yellow (Pin 2)...And White/Blue (Pin 1)...Pin 1=Ground and Pin 2=Battery when Relay pulls and contacts close...
The Blower Resistor Pack (Which fails often) controls the fan speed...BUT, there is a fuse inside the assembly...If it blows = No Fan...Located on the top of the heater/AC box and can be accessed through the Glove Compartment...Guru...Saailer
Jun 01, 2012 | 2006 Toyota Tacoma
I have a 2006 Toyota Tacoma the heat is always on but the blower will shut of what should I check to fix this problem i don't want to clamp the heat either I want air conditioning
check the heater inlet valve. it is located in the heater inlet hose usually near the firewall in the engine compartment. It is vacuum operated but could be stuck in the open position.
Feb 09, 2011 | 2006 Toyota Tacoma
Low and medium heater blower inoperative on 2006 toyota tacoma.
Resistor blown in heater. Follow the wires from the heater motor ( in foot well ) to a plug in the ducting between the fan and main heater body in centre of car. Unplug and remove the plate , it should be held in by a couple of screws. The plate should have a couple of wire coils of which , a couple will be broken. Replace resistor and heater should work.
Happy heating Marshall
May 05, 2010 | 2006 Toyota Tacoma
My 99 tacoma the fan blows but not hot air. the thermostat is good and full of antifreeze.
You need engine heat, circular, and a blower to get heat. You've already done the first steps of making sure you have enough fluid, etc.
Circulation - water pump - not likely because when they fail they usually bind up or leak really badly.
Heater core - would be my next guess. If this is blocked you won't get any hot water to blow air through. The heater core goes through the firewall. If you can get to the hose connections, disconnect them and see if you can flush any water through the core. Most likely you will have to replace it.
Mar 28, 2010 | 1999 Toyota Tacoma PreRunner
2005 toyota tacoma ac won't blow any air
check the blower motor to see if it has 12 volts when the switch is set on high blow poistion, if it does replace the switch, if it doesn't replace the blower motor
May 30, 2009 | 2005 Toyota Tacoma
Air flow weak when set to heat
check for dirty cab air inlet or "HVAC" filter, or heater core is plugged from debris and air is being restricted and wont blow through. it works like a radiator, air ducts can also be getting stuck.
Jan 06, 2009 | 1983 Toyota Camry
Blaupunkt IDC-A09 5-Disc CD Changer Logo
639 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
