Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Clogged draianage refrig has horrible odor, could drainage be clogged?
  • 108 Answers
For sure. Is there water in the drain pan under the unit? If not this is suspect. But first be certain the fridge is level! This is important.
Ray
Posted on Jan 05, 2009
The refrig has stinky smell after not opening it for two weeks without any spoiled food.
Is it a moldy odor or rotten food odor?
I suggest cleaning interior and then spraying with odor remover like: Nok Out Odor Eliminator and Sanitizer
Mar 20, 2016 | Refrigerators
A horrible sickly sweet smelling odor blowing out back of refrigerator
would check ur drain lines for food residue that rotted u may need to defrost and clean the drain line in freezer and fridge
Jun 22, 2015 | LG Refrigerators
Where to I check to see where filter is on dishwasher
I do not think there is a replaceable filter on this dishwasher - it is supposed to be self cleaning. If you put some bleach in the dishwasher that should knock any smell out of any standing water. If the odor remains, perhaps it is another source? Something behind or under? I once had a terrible odor from the fridge and cleaned the entire thing out with bleach water - still remained. Finally found a dead mouse behind fridge...
Mar 11, 2014 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dead fish smell
Try putting in pie pans filled with loose coffee grounds for a couple of days. Might take a while to permeate the refrigerator. Then clean with vinegar and leave dish of vinegar in there.
Apr 29, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water stays in the gasket and smell horrible, and the mold is there
The drains have probably clogged up and needs to cleaned out. The only resolution for the odor is to replace the gasket.
Jun 15, 2011 | Washing Machines
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a top load Sears Kenmore washer, miodel #15842, purchases in 2004. It has a horrible odor coming from it & I'm wondering if a filter is clogged. How do I open the top of the machine to take a...
You will find a screw attached to the drum, which keeps it intact to the structure. Unscrew it and pull the drum hard to take it out. Clean the components using running water.
Aug 19, 2010 | Kenmore Washing Machines
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
Bad odor in freezer
the only source for odor in a refrig is from food. check to be sure that nothing has gone bad in the refrig section as well as air circulates back from the fresh food section as well as the freezer. if you stil cant find odor source try charcoal or unscented kitty litter in a small container to help remove bad odors..
Dec 12, 2007 | GE GSS25JEMWW Side by Side
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
114 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
