After i have downloaded updates, it says configure failed, after configuring windows updates it stops at 15% thank you
Try this: Start your computer in safe mode with command prompt. For more information, see Start your computer in safe mode. At the command prompt, type rstrui.exe, and then press ENTER. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Windows XP
To start System Restore using the Command prompt, follow these steps:
Windows 7:
SOURCE: configuration
Hi
To reinstall the complete system you need CD that came with the computer, You can get from Toshiba by calling 1-800-457-7777. For the drivers for each device you can download free of charge from http://support.toshiba.com Hope that will fix your problem. If you need further assistance please post your question
Good Luck
SOURCE: Side-by-side configuration
The "side-by-side" component is associated with the Vista Windows Resource Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair these files.
To do this, follow these steps:
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow/Continue.
2. Type the following command, and then press ENTER:
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces incorrect versions with correctMicrosoft versions.)
This may take some time to run, so be patient.
Hope this fixes the problem.
SOURCE: Updates not configured correctly Reverting
uninstall the updates : if you are using vista then go to contolpanel, click on programs, and then programs and features, and on the right hand side panel you would find view installed updates, select all of them or those which you know are causing the problem , and uninstall them , and also go to windows update in the control panel and then click on change settings and then click on check for updates but let me choose whether to download and install them..
SOURCE: wireless zero configuration is not activated
What are you using Internet Explorer? Anyway I would try using FireFox or some other browser to see if they can complete the downloads.Then if a different browser works the one you are using is faulty and needs to be reinstalled or use the other one as default.The zero configurator is to help you setup and find your wireless conections your router will also have a wireless configutator then the one that windows comes with make sure you know which one you are using.Go to network connections and internet connections, click, then right click on wireless connection,then properties and you should have a wireless tab check to see if the box that says use windows to configure my wireless conections is checked if you want windows to do it. If neither browser finishes downloads redo wireless setup.But I really think it is the browser.Hope you understand what I am trying to say.
SOURCE: acer 5570
Several things you can try...first, if System Restore is enabled (not recommended because viruses love to eat and grow in there), boot into Safe Mode (F8 at startup). If you can get into safe mode, go to Start, Programs, Accessories, System Tools, System Restore ...the SP update automatically creates a restore point before it begins (about the only thing that Microsoft actually got right!), and you should be able to select that restore point and go back to before you ran the update.
If that does not work, or you cannot get into safe mode, then you will need to run a Windows repair using your original Windows CD or factory recovery disc(s). Make sure to run a "repair", not a "clean install", else you will lose all your data. (if you don't care about saving data, I recommend a clean install).
If the repair doesn't work, your only real choice is to do a clean install, following the steps just above. However, you will lose all your documents, so if they are important to you, take your computer to a PC service tech or facility and have them backup your files first. It'll cost you, but probably not that much. I normally charge my clients $60/hr to backup their data, and usually it only takes about 30 minutes for 1-5GB of data.
After that (or without that), run the Windows "clean" install and you're back in business!
Hope this helps - remember to rate :)
Scott
