How to tune my digital chanels in my bush lcd tv
I can see all the analog channels but when I switch it to dtv I get a blank screen. I want to tune it to free view channels. It has the freeview facility and I used to watch All DTV channels 2-3 weeks ago but now I can not.
  • 1 more comment
  • Anonymous Jan 30, 2009
    I have the same problem. I just hooked up an antenna to replace a cable box, and nothing but analog channels. DTV is blue only.
  • lysa182 Apr 18, 2009
    I just bought a Bush Digital TV and I can;t sem to tune any of the channels. DTV is just showing blue. I an even get normal channels. Not sure what need to be plugged into the tele to get channels but I would have thought it should work. Help!
  • Anonymous Mar 22, 2014
    CARNT TUNE THE TV IN ONLY ON DTV WHY
I just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
How do I go back to Digital add on search when my boyfriend scanned for the analog channels. Sanyo TV model # dp42545
Usually you have to go to chanel setup and scroll down to DTV setup up or DTV auto tuning and click on the remotes enter button and choose to scan for the Digital channels (DTV) Then tell your boyfriend that they don't broadcast in analogue anymore.
May 09, 2015 | Sanyo Televison & Video
Is the TV Tuner in the 8806 analog only? It cant be used for OTA DTV?
GPX KCL8806DT television receiver has only an analog broadcast tuner to receive digital from Time Warner you will require a converter box.
Feb 17, 2015 | GPX KCL8806DT 7 in. Portable Television
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
My DTV stopped working giving a blank screen
It may just need to be Re-tuned.
What I would suggest you do is make sure that you are on a DTV channel on your Tv. then with your Pioneer remote press the menu button and then set it away on a Auto tune.
You must have it on a DTV channel first before try to tune as if you mistakenly have it on TV (terrestrail channel) It will only Auto tune that and not your freeview.
Hope you get it sorted.
Cheers Little Dish Fitter
Oct 06, 2009 | Televison & Video
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Air Digital No signal on the screen. Cannot change channels
hi my name is mark, since you have a cable box. you need to switch the tv back to the analog signal on the tv through setup or menu screen. then use cable remote to change channals. thanks for your question.
Dec 26, 2008 | Mintek DTV-263 26 in. LCD Television
Televison & Video Logo
2,333 people viewed this question
Top Televison & Video Experts
