Question about Zenith C27A24T 27" TV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
Channel up and down buttons on the front of the tv do nothing except blink the screen. I'm trying to set up direct tv, need channel 3 and can't get there. Remote is 1500 miles away.
  • 106 Answers
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Posted on Dec 19, 2008
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Only showing 3 channels.
you need the remote. it is the only way, unless you have a menu button on the front of tv...sorry, wish i could help more
Dec 16, 2008 | Zenith C27A24T 27" TV
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Jul 20, 2008 | Zenith ZN620 Remote Control
ZEN-SPA UNIVERSAL REMOTE CONTROL
Manually turn on the device( TV.,VCR,etc) to be controlled.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the code search button.
Press and quicly release the desired mode button(TV,VCR,etc).The red indicator blinks off once.
Press the CHaNNEL UP button repeteadly(up to 300 times) until the device to be controlled Changes Channel.The red indicator blinks off with each button press.If you overshoot the code required,press Channel Down button to backtrack through the library until the device changes channel.
Press and release MUTE to install the code.
May 29, 2008 | Zenith DBZN-311 Remote Control
Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
May 28, 2008 | Zenith C27A24T 27" TV
Zenith Concierge H25W35DT 27"
The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
Mar 09, 2008 | Zenith C27A24T 27" TV
Zenith SR3238RK
You have to access to the service mode , press at the same time channel up & down and the adjust button up , you will see a menu, find with the remote the funtion channel lock the values are 0 or 1 select 0, now Should be in 1 and that`s because you can not change channels , good luck , please dò not change any other value or better, writte down all the values before you change any.
Dec 29, 2007 | Zenith C27A24T 27" TV
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
235 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
