Question about Mastercraft Garden
Snowblower runs then quits
Snowblower starts, but seems to run a little rough. Forgot to run stabilizer through it at end of last season. Drained old gas out, put in fresh gas, added a little carb cleaner. It will run for about 5 minutes and then quit. Do not put it under load, let it sit there at full throttle. Then it just quits. Seems to be starving for fuel. Let it sit for another 5 min. restart it , runs again and does the same as described above.
Please help!!!!!
Check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Posted on Jan 07, 2009
Toro snowblower surges what could be wrong? Any help will be appreciated. Thanks
Try removing the needle from the carburetor and soaking it in brake fluid (and any other parts that may look suspicious) over night; clean and regap or replace spark plug; ...also, try using high test fuel.... this runs cleaner on my Toro826.
Jan 06, 2018 | Toro Garden
I bought my son a craftsman snowblower last winter we can’t get it to start.It tuns over and over.Help needed.
If last year, you didn't drain the gas from the tank and carb or put fuel stabilizer in the gas, the old gas has gunked up the carb.
Remove the air filter and squirt starter fluid into the carb and see if it will crank. If it runs even a little bit, your carb needs cleaning.
Jan 05, 2018 | Craftsman Garden
Mastercraft Snowblower 8hp28inch cut.Snowblower starts to miss and run rough after it is warmed up what is the problem
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=manual+for+a+Mastercraft+8+Hp+snowblower
Feb 05, 2016 | Garden
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Ariens snowblower won't start
Did you drain the gas from last year? Gas is only good for a few Months. You should always run the machine dry at the end of the season or add Fuel Stabilizer at the end of the season. Id start by getting all the old gas out of the tank and the fuel Bowl on the carburetor. You will also want to check for spark. to make sure there are no electrical issues. Check oil level also. Depending on machine it may not start if oil level is to low alot of machines have a oil pressure switch.
Dec 14, 2013 | Garden
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
Homelite ut10515
most newer 2 cycles call fro 50:1. That's so the environmental people smile a little. Do yourself a favor, make the ratio 40:1 and the saw will outlive you
Oct 05, 2013 | Garden
Troy bilt snowblower 123cc starting problems
Carburetor might be gummed up with old fuel. I would recommend carburetor overhaul. That should be the fix. When storing your snowblower till next use, either run the engine until out of gas or add fuel stabilizer to fuel tank to prevent fuel break down that causes damage to carburetors when not used for a long time.
Dec 30, 2012 | Garden
Garden Logo
462 people viewed this question
Top Mastercraft Garden Experts
john h
DROPNDEAL
DROPNDEAL
ray gallant
Are you a Mastercraft Garden Expert? Answer questions, earn points and help others
