Question about Maytag Washer Timer - 22004015
MAYTAG TOP LOAD WASHER TOMER REPLACEMENT (Mod# LAT9206BAE)
How does the dial on the face (backsplash) of the washer come off - so I can gain access to the timer screws?
Thanks
  • ldolson2003 Jan 12, 2009
    Maytag top loader timer needs to be replaced.
Maytag washer fills but don't agitate
Posted on Aug 17, 2010
2 Suggested Answers
  • 122 Answers
SOURCE: Top load Maytag washer about
You might have a sensor problem that prevents the cycle from proceeding.
Most washers have a sensor that detects the water level, thus allowing the selection of Small, Medium and Large loads and the related water level.
Some sensors also use a breather tube, which can become clogged with fluff or debris, causing the same symptom.
Only when the sensor activates, will power be applied to the timer or rotary control unit's little motor, thus causing the cyle to proceed.
Posted on Jun 08, 2011
How do I open front panel of Maytag washer ?
2 screws at bottom of front remove. Then pulling from bottom towards you until the clips at the top of the front panel clear the top of the machine.
Nov 20, 2016 | Maytag Washing Machines
Water will not shut off when washer is full on any level setting
There is a tube that goes from a sensor near the bottom of most washers and fits into a fitting near the dial that selects the size of load you will be washing. This tube probably came off of its fitting at one of the ends. Take off the top panel and check behind the dial first. If that looks good you will have to take off at least the front panel of the washer to gain access to the sensor
Jan 13, 2014 | Kenmore 24032\24036 Top Load Washer
I put in a too large of a load & now it wont spin & the door is locked...what should I do
See this post..... my Clutch Fix post. Follow this paragraph and reference the Service Manual to release and raise the washer top from the base to gain access to the wash basket and your load. Apr 24, 2009 - by dh1200s - Disconnect 120VAC power cord. Read and follow all safety warnings in the Service Manual The Service Manual for reference. Sears Parts Direct for reference. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5? from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. Rich
May 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I NEED INTO GET INTO THE TOP OF THE WASHER TO REPLACE THE OPEN LID KILL SWITCH
You should be able to remove / open the top control panel (rear top) screws and tip it out forward to gain access to the lid switch. Be careful of the small air line that goes to the pressure switch. If that comes unhooked your machine will over fill.
Jan 12, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Little black tube fell off rom under washer what is it and how do i fix it i have a maytag top loading washer
This is from where your water is pumped out down the drain after the was and rinse cycles. It is attached with a hose clamp. Gain access to the attachment coupling, refit, and tighten the clamp.
Jul 26, 2009 | Maytag SAV5710 Top Load Washer
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Stacked washer it fills up but it doesnt cycle
Hello, sounds like you have a faulty lid switch . The lid switch is located behind the tub in the right rear, the front panel and the washer top panel have to be removed to gain access to the switch assembly. good luck
Dec 22, 2008 | Maytag LSE7806A Top Load Stacked...
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fabric softner leakage
By opening upper machine's cover you will have an access to the detergent/softner drawer. Look for the place the water leaks from. Good luck !!
Sep 03, 2006 | Maytag PAV2300 Top Load Washer
Maytag Washer Timer - 22004015 Logo
884 people viewed this question
Top Maytag Hardware & Accessories Experts
Hippy_dd
ray gallant
Are you a Maytag Hardware and Accessory Expert? Answer questions, earn points and help others
