Alpine CDA-9835 CD Player
Problem for Alpine CDA-9835 CD Player
Finding treble and bass adjustments on my stereo
By tyson15 on Dec 19, 2008
ive looked and can not find the settings on my stereo for the bass and treble can you explain how to get there cda-9835
Comments:
Dec 19, 2008
- thanks but you cant see the manuall and i need somebody to just explain it to me that would be a big help
Solution #1
posted on Dec 19, 2008
Somewhat Helpful)
jyackle5
Rank: Guru
Rating: 90%, 1255 votes
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
http://vault.alpine-usa.com/products/documents/OM%20CDA-9835.PDF
Good Luck Please Rate FixYa!
Comments:
Dec 19, 2008
- cut and past in to browswer. Where you see the printer icon look to the right and put to 100% then you can read the manual
Dec 19, 2008
- 1 Press and hold MENU for at least 2 seconds.
2 Press MENU to select USER EQ (USER'S EQ for
CDA-9833).
3 Press BAND/TEL. to select your desired
frequency band.
BAND1 → BAND2 → BAND3 → BAND4 → BAND5 →BAND1
4 Press g or f to select your desired
frequency.
Adjustable frequency bands:
20Hz to 20kHz(in 1/3 octave steps)
5 Turn the Rotary encoder to adjust the level.
Dec 19, 2008
- 6 Press SOURCE/POWER to select your desired
band width (Q).
Adjustable band width: 1.0, 1.5, 3.0
To store the adjusted curve
1) Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish to store
the adjusted curve.
7 To set another channel, repeat steps 3 to 6.
8 Press the Rotary encoder to confirm the
adjusted contents.
The adjusted contents are not stored if the Rotary encoder
is not pressed.
9 After setting, press MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
Was this helpful?
Yes
No
Popular Solutions for Alpine CDA-9835 CD Player
Questions and Unsolved Problems for Alpine CDA-9835 CD Player
Do you recommend Alpine CDA-9835 CD Player?
Answer
Answer
2010 chevy equinox all bluetooth connectivity lost
Answer
how do I disable the clock display on a nakamichi TD-35z?
Answer
i have 2000gmc jimmy with a bose system i replaced the stock radio with apioneer deh-p47dh and... (More)
Answer
I just plug my Alpine CDA-9835 and when I turn on my ignition switch, everything works but not the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top In Dash Receivers Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
