Question about Kicker ZX650.4 Car Audio Amplifier
Resistor values Someone had an amplifier(Kicker ZX650.4) turned on and began changing subs and touch wires a few times and the red protect light now flashes on and off every so many seconds. It was opened to be repair and I found that 4 half watt resistors are burnt(R468-R168-R368-R268). I can distinguish three to be 4.7ohms but due to the singe on R368, I can not tell. Could you find the values of these resistors for me for safe repair?
    Top Expert:
  • Kicker Master
  • 49,919 Answers
Request a schematic diagram and parts list from Kicker.
Posted on Jul 15, 2017
2 Suggested Answers
  • 113 Answers
SOURCE: i have a kx650.4 and it isn't working i found two
no matter the maker the markings r all the same value so find another resistor with the same markings and that should work just fine
Posted on Jul 04, 2009
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
My kicker dx 500.1 and my xpliod tens worked for all of ten seconds before the protect light went red then green keeps doing that
You are running more then 1 speaker on a 1 channel amp. You need to verify how many ohms your subs are, and what ohm you are wiring your subs to run at. Your amp is only capable of running at 2 ohms.
Here is a link to figure out how to wire them correctly.
http://www.crutchfield.com/S-FKw5viheGLo/learn/learningcenter/car/amplifiers/sub_amp_guide.html
Here is a link to your amplifiers specifications.
http://www.kicker.com/dx_amplifiers
Jun 06, 2011 | Kicker Car Audio & Video
Was loud, now quiet, never changed any setings.
there are many possibilities here:
-one of the subs came unplugged?
-you blew one of the subs
-your amp is over-heating
-some wire has been fried in your amp
-the RCA outputs on your cd player are going bad.
May 09, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
Hello. My Kicker kx200.4 is acting funny. The red display light on front/top of the amp is turning on for a second and then turning off, repeatedly. The light on the side (power) is also turning on, red...
the amp is a 200 Watt by 4 im guessing and its doing that because its going into protection mode unhook the subs if it stops then 1 you have a bad sub or 2 the subs are too much for the amp if an amp is rated 200w per chanel its 200 max about 75 rms or 75 normal constant power
Feb 05, 2010 | Kicker KX200.4 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Protection light won't stop blinking/ Subs don't work
The amp probably has shorted output transistors to eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 07, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker ZX650.4 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
