Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Home healthy bissell vacuum
I saw that you know a lot about the home healthy bissell... ours works and we cleaned changed the filter everything but it just doesnt seem to be sucking like it use to.... it picks up some thinks but some things it just spits back out... the brush is working... filters are new ... but it just doesnt seem to be working like it use to... we have owned it about 2 almost 3 years we got it when it first came out... any help you can offer would be great... my email is unrulyjessi@sbcglobal.net
  • 281 Answers
Your intake hose is clogged.its the clear hose that comes up from the bottom and up the backside of ther vacuum.take the screws out that hold the hose connector on and then take a coat hanger and bend the tip so it is round then work it down into the intake hose.you might be able to push the clog out the bottom
Posted on Apr 13, 2009
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Apr 05, 2013 | Bissell Healthy Home HEPA Bagless Upright...
Bissell healthy home vacuum will not turn on. I have checked everything on the vacuum. All the filters are clean and there are no clogs. I have had it for 10 months with no issues until now.
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 06, 2010 | Bissell Healthy Home HEPA Bagless Upright...
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
Dec 07, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Brush wont work
You probably need to change the belt. You can get a replacement here:
Bissell Healthy Home Belt
Nov 21, 2009 | Bissell Healthy Home HEPA Bagless Upright...
No suction at base of bissel vacuum cleaned everything
you have to go deeper in side where the filter is, probably clogged.
Sep 06, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell Healthy Home 5770 Fails to Turn On and Has No Suction!
I have the same problem sometimes...I noticed that the main body sometimes comes apart (the two sections under the turbo brush) and you just have to line them up again. If this is what's happening for you, try that. If they are still lined up, I'm not sure what's going on. Recently my brushes stopped spinning and eventually they just came back on...don't know why, but I'm guessing the contacts inside the vacuum are dirty or some things are coming loose.
Feb 01, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell Healthy Home Vacuum
easy fix- mine did this too for a while bfore I figured out the handle wasn't aligning properly where attached. Give it a smack to realign it and it works again
Dec 03, 2007 | Vacuums
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
131 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
