Question about Philips Magnavox 9P6034C 60" Rear Projection Television
T.v will not stay on!
My magnavox rear projection t.v, model #ptv910 will not stay powered up! it shuts down after only being on a few minutes. it seems to go into standbye mode as the red light on the front panel keeps blinking!
  • Mrbecky255 Dec 23, 2008
    there is a flash code....it flashes 4 times and then off then flashes four times and then goes off. I'm told that that is a code that may tell what's wrong with the TV , I'm becky's husband....same TV.
    it turns on, warms up, then right before the picture comes up, the power light starts blinking.....4 times then a pause then 4 times, then a pause....also the buttons on the front acted crazy before the above mentioned problem started. the channel buttons would either turn the TV off or bring up the menu....the volume buttons worked properly. I'm thinking that that board on the front is bad......but there is something else that is causing the other problem. I called a repair man and he wanted $85 just to look at the TV....with no guarantees that he could fix it or get the parts, or even find the problem.
    so I wound up buying a phillips 47" LCD for her so she can watch football without binos
    I hope no one else wanted presents form me this year :P
  • ppcphillips Jan 01, 2009
    I am having the same probem where it blinks 4 times and then shuts off. No picture comes up. We have had this problem for a while but seems like if we unplug the TV for a while, it works again. That is no longer working. I have not been able to get my TV on for 5 days. I called for service and they wanted a fortune for just the call. I am thinking I should just repace it. If anyone has any suggestions, I will take them. I did not really understand the solution that was given below. HELP!
  • Philips Master
  • 5,138 Answers
The SSB board will cause this if its the one am thinking it is cost of board if AVL 295.00, other cause of problem STKs convergence ICs STK392-560 Go by part number on STKs, they are big black ics.; 2 of them.
Posted on Dec 22, 2008
Magnavox ptv910
The coolant in the green and blue tubes has discolored causing the red to dominate the screen,. This is a common problem that you can fix yourself with a CRT or Dull video repair kit from www.TvRepairKits.com
Dec 24, 2011 | Philips Magnavox 9P6034C 60" Rear...
Need the board of an philips magnavox model PTV910
Which Board are you needing? Let me know and I can assist you.
Jan 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox PTV910. The picture is good but color is bad
the coolant in the blue and green crts has congealed which is causing the red tube to become dominate. The coolant can be changed at home. You can get the phillips coolant replacement kit at the following link which contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 15, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rear projection
Sounds like the red CRT is shorted. I have some magnavox/phillips crts listed on my website for about a third of what they normally go for and i am currently adding The CRTs from a PTV910 43P8431. let me know if you would like me to post a link to the website.
Mar 07, 2008 | Televison & Video
Zenith m52w56lcd
to me sounds like ballast or power supply
Dec 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Magnavox tv
This might be a power supply issue either in the switching power supply or in the high voltage power supply. In any case you will need a schematic, a voltage meter, and if possible an oscilloscope to troubleshoot this problem. If you do not have a background in electronics I would suggest that you take the TV to a repair shop.
Oct 04, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
