Question about Harman Kardon AVR 300 Receiver
When I turn the amp on the view screen flashes protection
I purchased the amp from a second hand shop down town and when I brought it home I plugged it in , turned it on and received the protection instruction. I immediately turned the unit off and began to research the problem. I currently do not have any speakers hooked to the am. Would that cause me to receive that error do to an imbalance?
  • jcannon1969 Dec 20, 2008
    I attempted to try the amp again after cleaning the amps speaker terminals and cleaning the entire unit. I researched the problem throughout the night and found no solutions that work. Please help.
    John Cannon
    The amp is a Harmon Kardon AVR300
    Guru:
  • 449 Answers
The Speaker not hooking up could be the problem John but it could also be that one of the channel(out put) is shot, but let us not jump to conclusion hook the speaker to it then try again.good luck buddy
Posted on Dec 20, 2008
  • 679 Answers
John I would take it back, unless it's a fuse it is extremlly to difficult to troubleshoot that kind of problem over the net. you need the schematic, which may be nside on the panel, but then you need a voltmeter and the like, just not worth it. Take it back before they tell you that it's not their problem, which they will do if you wait. Here in Florida they have to giv you a refund if it's within 3 days,, check yout local laws.
  • Harman Kardon Master
  • 19,396 Answers
Protection is caused by a short ,m a bad voltage, or a component that has blown.
Unplug power cable, if you still get protection, then the unit is faulty, get your money back.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, most current designs of receivers/amplifiers have built-in diagnostics that triggers the protection mode to kick in if the diagnostics senses a fault. One of these faults is a short in the speaker/speaker wire. The opposite also holds true, it would trigger protect is there are no speakers connected. An amp would self destruct either way, shorted speakers or open speakers (or as in your case, none connected)
Good luck and Thank you for using FixYa. Happy Holidays.
  • 470 Answers
What is the model of your AMP??
Ive brought a second hand morphy richards icon stainless steel bread maker ive done every thing with the ingredience pluged it in press select and it is flashing 5EL isnt working
probably is why it is second hand -- it had the problem for the previous owner who failed to disclose that it wouldn't work
go google and type in--- user manual for morphy richards bread maker--- and if there is a manual in pdf version down load it and see if there is a trouble shooting section
Jun 24, 2016 | Morphy Richards Kitchen Appliances -...
I brought a second hand 3 g iphone offline. When it came it was unlocked, i put it on itunes and it said that the sim was not supported, so i restored it. Now I have nothing on the phone at all ,just to...
Follow these steps to try and get your phone running - although I cant guarantee it is unlocked, you'll have to take it up with whom you bought the phone off but if they unlocked "jail broke" it themselves and not via their network which they where locked to then it is most likely the phones software is altered with and restoring it will make no difference....
Power up your computer & itunes & make sure you have updated your itunes then power down your iphone and follow the steps below!
  1. Hold down the home button and continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button *** if this doesn't appear then release button and hold down again for around 6secs and then still holding the button plug into the computer***
  2. The above message will appear in iTunes
  3. Continue with the restore option and when you get the screen to setup the iphone select restore as new iphone
Like i said before, if who you bought the phone from unlocked it themselves then its most likely the software is affected within the phone
Dec 30, 2010 | Apple iPhone 3G
I have just brought a second hand simpson eziset 750, it worked at the shop and now only goes halfway through the cycle. The water level lights are all flashing and beeping like crazy. i have tryed to...
There is a magnet in/under the lid on the left hand side inside a plastic housing. I also got a second hand machine in which the magnet had totally broken down due to corrosion. You can test if this is the problem by placing a magnet where this magnet would be positioned when lid closed. Replace magnet
Sep 05, 2010 | Washing Machines
It dont turn on. theres red light flashing. is like in protection or something, it last a few seconds and then turn off.thanks for your cooperation
If you have done a reset by holding down speaker a and b buttons while plugging in. Hold buttons for a few seconds then release.If goes back to protect mode then you have a shorted output channel. Most repair shops will charge from 150-200 for repair, there is a lot of parts you have to replace on this model.
Apr 01, 2010 | Denon AVR-1905 Receiver
TV KEEPS TURNING OFF AFTER A SECOND OR TWO AFTER BEING SWITCHED ON. bottom left hand red light keeps flashing red once tv goes off? any thoughts? dave@fruitheads.com.au
Power supply needs repair or theres another circuit fault causing the tv to go in protection mode and shuts down....
Your tv needs servicing at your local repair shop........
Nov 03, 2009 | Televison & Video
Protection displayed and shuts off
the solution is get rid of it fast , i had a samsung dvd player that did that then it caught on fire , pretty scary,lucky i was there when it started to smoke up
May 23, 2009 | Samsung HT-X40 System
Duo Therm A/C unit will not run
It appears you may have a bad fan motor the reason the compressor stops is it is kicking out a low pressure switch to protect the compressor. You may be better taking it to an RV shop because I think you will have to remove the evap coil to change out the fan motor.
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
Apr 29, 2007 | Onkyo TX-SV373 Receiver
Harman Kardon AVR 300 Receiver Logo
60 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
