Question about HP vs15 15"LCD Flat Panel Monitor
Sound on my cpu doesn't work properly
It all started when i realized i could use my brand new plasma tv as my cpu monitor. i switched the wires from my monitor to the plasma. the picture was perfect but the sound never worked on the tv. whenever i wanted to play the sound, the tv never made a noise but the my old monitor did. so for a while i would use my monitor as the sound and use the tv for the picture, they were a team. so today i turned on the plasma and the monitor but the sound doesn't work on the monitor anymore. i disconnected all the wires from the tv and put them back on the monitor and the sound still doesn't work properly. the monitor makes some sounds but it doesn't make noise when i play a song or when i click on the little speaker on the bottom right part of the screen(the icon next to the time). i don't know what to do.
  • garcia04 Dec 20, 2008
    why would i buy speakers when it makes certain sounds loud and clear but doesn't make other sounds
GET NEW SPEAKERS DUHHHH!!!!!!!!!!!!!
Posted on Dec 20, 2008
No HD pic on Samsung HP-R5250
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
The PC is dead, no fans run or anything. It will not power up so I bought a new power supply and installed it but still the same issue? It does have 120 vac power into the power supply.
maybe your CPU is busted.try to replaced a new processor and test it.or double check the setting of the power on *********** board switch,maybe you inserted wrong.
Jul 11, 2011 | Computers & Internet
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
When I start my CPU, I hear a sound that shows me that the equipment is on (that it's working), but the screen stays completely black, no light, no image on it. It happened all of a sudden. I switched it...
that iis not clear from wheryou heare sound.. monitor or cpu. if u hear sound from cpu your cpu fan is not working properly.. that cause processar may be damage,2/ some time damage ram shown same type symtom.change it to find outfault.
Jun 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Brand new LG plasma has no picture and only static noise.
This is brand new!! I would recommend talking to the store about this since it is under warranty?
Jan 03, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Monitor goes to sleep mode quickly without video cable
right click on desktop - click properties - click screensaver tab, and dropdown menu to none. this turns off screen saver. For power/hybernate....
start - control panel - power options. Change all pull down menus to "never"
Problem solved.
Dec 22, 2008 | HP vs15 15"LCD Flat Panel Monitor
Green Screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work. If that doesn;t work you can replace the cord and if that doesn't work then the screen is out and would cost WAY too much to fix, you could buy you a new name brand TV.
Dec 12, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Cpu
central processing unit,cpu are all driver of tv like sound,picture,switches malfunction and etc.
Jun 14, 2008 | RCA 32F531T 32" TV
HP vs15 15"LCD Flat Panel Monitor Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
