Question about Brother GX-6750 Typewriter
I put in new Brother ribbon - won't type. I hit code reset.
The key strikes, but it doesn't seem to be hitting the ribbon.
  • bettemccormi Dec 20, 2008
    Thrilled with the fix! And such a fast response. Love you.
    Scholar:
  • 183 Answers
MAKE SURE THE RIBBON IS INSTALLED CORRECTLY AND IS BETWEEN THE TWO METAL "FINGERS" AND THE CARDHOLDER AND THE PRINTWHEEL IS LOCKED INTO PLACE (JUST PUSH FORWARD ON THE BLACK LEVER TO THE RIGHT OF THE PRINTHAMMER
Posted on Dec 20, 2008
What do I do when my typewriter types different letters and symbols than the keys being hit
Turn the machine off then on or hold down the "code" key and hit Q "reset" key to get the machine to type the correct keys. This usually happens because something interferes with the free rotation of the printwheel. Check to be sure the ribbon and corredtion tape are installed correctly and check to be sure none of the "fingers" on the printwheel are bent outward. If a finger is bent, bend it back. If everything looks okay, the board or power supply is going bad.
Feb 23, 2015 | Brother GX-6750 Typewriter
Hammer won't strike
1.If your unit is not printing check the ribbon cartridge to make sure it has not run out.
2.If the ribbon appears silver or gray install a new cartridge. Also make sure the ribbon is advancing in the cartridge.
3.Next make sure the black lever in the center of the carriage is pressed toward the paper. If not, press the black lever toward the paper to lock the daisywheel into place and reset unit by holding down the "CODE" key, while holding the code key down press the "REST / Q" keyand release both keys.
4. Try typing. If problem still exists contact an Authorized Brother service center. You may do so at 1-800-284-4357 or by visiting our website.
Apr 22, 2013 | Brother GX-6750 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
NAKAJIMA AE-800
hitting "code + /" puts ribbon drive mode into multi-strike ribbon mode, to correct this hit "code + ."
Oct 23, 2008 | Nakajima AE-740 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Beeping sound when powering unit on
Have you simply pushed the carriage back to the middle? If it is like the ML100 (it looks the same) you can just push it over ...with the pwoer off. Then put in you new ribbon. And this time, when you turn it on, it is the new ribbon that hits a switch on the underside of the keyboard, located to the upper left. If you do not have a ribbon installed, it will travel all the way to the left, and beep, beep, beep, beep. ,,,, The switch is hit with the ribbon housing.
Jun 25, 2008 | Brother ML-300 Typewriter
Typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Feb 06, 2008 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
203 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
