Question about M&S Systems AirVac AVP1200 Platinum Series Central Vac - 12,000 sq ft Bagged Central System Vacuum
Vac running and won't shut off
When I pulled the hose out of the wall the motor kept on running
  • joannburkhol Jan 05, 2009
    This solution was very helpful to check out what was wrong. We discovered the switch inside and replaced it for $43. We had been told by a company that we would have to replace the whole thing for $600. So this was considerable savings. thanks
    Scholar:
  • 44 Answers
The first thing I would do is to disconnect the low voltage wires from the unit. Does the unit continue to run? If so, it's probably an internal relay sticking in the unit. You can fix this yourself is you are handy, but I suggest calling your local dealer if you have any doubt. If the unit doesn't continue running, than you most likely have a short in low voltage wiring in your house. Check your inlet valves first by removing the screws and looking behind the faceplates. If you have inlets that are powered with 110v for you power nozzle (Supervalves, or Electravalves), be very careful as you could be exposed to 110vac. Check your vacpans too, if you have any. The wires should not be touching anywhere. If the two wires touch, the machine should come on. Good Luck!!
Posted on Jan 01, 2009
My rigid shop vac 4.0 has no suction
If the motor is turning on then the issue is one of three things blocked exhaust, blocked intake or the fan that moves the air is loose on the motor . The last doesn't happen as much but can. First thing is to make sure the safety ball hasn't become stuck in the intake line. ( this ball stops water from reaching the motor when using it in a wet environment.. If the machine was knocked over while running or was used to suck up water the ball may be stuck) to fix this , remove the wheels from the bottom of the canister , with the machine off raise it and bang it on the floor several times . If you hear a ball drop then that was your issue. If not Disconnect the hose and see if you have suction at the intake. If you do the problem is a blocked hose. Reverse the hose and try sucking the other direction. If the exhaust is blocked the Vac will come on but the machine will sound like it's under load. Try running it without the filters ( do not use in dirt until filter is cleaned and replaced.,). To check the suction fan requires unplugging the Vac from the wall and opening the motor shroud . Locate the fan , see if it is damaged or loose.
Aug 01, 2018 | Shop Vac Vacuums
Central vacuum won't turn off when hose removed from wall socket
There is a switch somewhere close to where you plug in the hose. Check and see if the switch is stuck in the down position. If so, it will either need to be replaced or cleaned to allow the switch to raise to the off position.
Semper Fi,
Z
Aug 03, 2017 | Vacuums
Electolux vavumn overheats shuts off
usually caused by a stressed out motor..... clean the hell out of it... hose, filters .... everything...there could even be crud down in the motor itself... which requires taking the vac apart and pulling out the motor...dont be afraid to take hoses off and wash them out and dry them before putting them back on.
Nov 09, 2013 | Vacuums
Electrolux 1590 not turning on
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Dec 12, 2009 | Electrolux Vacuums
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a Nutone central vacuum model number CV450W that was working great until I recently removed the hose and it now runs continuously until I pull the plug....any suggestions please
Disconnect the thin low voltage wiring between the vac and the rest of the house. If the vac continues to run you have a defective relay in the vac motor housing.
If the vac stops you have a short in the wiring in the house, likely behind an inlet in the wall.
If any inlets have been disturbed for painting or renos lately that would be the first spot to look in the house for a problem. Look for wires behind the inlet valve which are touching against each other or a mounting screw or against a metal mounting plate behind the inlet. Start at the last inlet used. Be careful not to loose the spring under the screws where the wiring attaches to the inlets
Oct 08, 2009 | Broan-NuTone CV450 Central Bagged Central...
Nutone CV556 Vaccuum Cleaner -Continuously running
Start with this. Unplug the vac to shut off, then disconnect the low voltage wiring at the vac.Plug the vac back in. If the vac still runs you have an internal short on the relay or wiring inside the vac.
If the vac stops then the vac and final wiring is OK and the problem is in the wiring in the house.
Have you removed any inlets for painting or had any renos done or pictures hung. If so undo what you did last. If inlets were disturbed remove them and look for low voltage vac wires touching metal backing plates in the wall or touching the inlet mounting screws.
If you have done a reno or hung pictures you may have pierece the wire for the vac creating a low voltage short which will keep the vac running until removed. I have seen this happen with freshly installed 1/4 round molding along a baseboard
Sep 07, 2009 | Broan-NuTone CV556 Cyclonic Bagless...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
M&S Systems AirVac AVP1200 Platinum Series Central Vac - 12,000 sq ft Bagged Central System Vacuum Logo
378 people viewed this question
Top M&S Systems Vacuums Experts
Thatvacguy.com
Electric Hospital
Electric Hospital
Are you a M&S Systems Vacuum Expert? Answer questions, earn points and help others
