Furniture Logo
Anonymous Posted on Aug 19, 2012
What is a slat bed? - Furniture
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
22
Helped
10423
Points
72
A slat bed is a type of bed with built-in frames that support the mattress without the use of a box spring. The slats run parallel to each other and are secured on each end to the frame of the bed.
1helpful
2answers
I need instructions for Natart Rustico to make a crib and to make a bed All parts disassembled and mixed A parts list for each would be great also
I'm sorry, but I don't have access to specific assembly instructions or parts lists for the Natart Rustico crib and bed. However, I can provide you with some general guidance on assembling cribs and beds based on common practices. Please note that these instructions are general, and you should refer to the specific assembly manual that came with your Natart Rustico furniture for accurate details.
General Steps for Assembling a Crib:
  1. Sort and Identify Parts:
    • Lay out all the disassembled parts and sort them according to their shapes and sizes. Identify key components, such as crib sides, mattress support, hardware, and any decorative elements.
  2. Follow the Manual:
    • Refer to the assembly manual that came with your Natart Rustico crib for specific instructions. The manual typically includes step-by-step guidance and illustrations.
  3. Assemble the Frame:
    • Start by assembling the main frame of the crib. Connect the crib sides to the headboard and footboard using the provided screws and bolts.
  4. Attach Mattress Support:
    • Install the mattress support platform according to the manufacturer's instructions. This usually involves attaching it to designated points on the crib sides.
  5. Secure All Connections:
    • Tighten all screws and bolts securely. Ensure that the crib is stable and does not wobble.
  6. Install Drop-Side Mechanism (if applicable):
    • If the crib has a drop-side, follow the instructions carefully to install the mechanism securely.
General Steps for Assembling a Bed:
  1. Identify Parts:
    • Lay out all the parts for the bed and identify the headboard, footboard, side rails, support slats, and any additional components.
    • Use the assembly manual provided by Natart for specific instructions. Follow the steps outlined in the manual for your particular bed model.
    • Begin by connecting the headboard and footboard using the provided screws and bolts. Attach the side rails to complete the basic frame.
  4. Attach Support Slats:
    • Install the support slats according to the manufacturer's instructions. The slats typically provide support for the mattress.
    • Ensure that all screws and bolts are tightened securely. Check the stability of the bed frame.
  6. Attach Additional Components (if applicable):
    • If there are additional components, such as decorative elements or storage features, attach them according to the instructions.
Parts List:
For a precise parts list, please refer to the assembly manual that came with your Natart Rustico crib and bed. The manual should include a detailed list of all components with corresponding part numbers.
If you do not have the assembly manual, you may contact Natart directly or check their official website for customer support. They should be able to provide you with a replacement manual or offer guidance on assembly.
Always follow safety guidelines when assembling furniture, and if you're unsure or uncomfortable with any step,
Dec 05, 2023 • Baby Gear
How to assemble Ashley bunk bed b213-58n
Contact Ashley Furniture to request assembly instructions.
Feb 28, 2021 • Furniture
We have another Home Sullivan bed that has a lot more slats. This one only came with three. How can I order more slats and leg sets for those slats?
If it is new then just return the bed or ask the place you bought it from to get you more slats.
If you bought it used order some.
If your are ambitious you can take a slat to Home Depot and they can cut and make you some more.
Sep 08, 2015 • Furniture
I have 4 metal rods that I am not sure where they are placed in between slats for bed frame. How are they assembled?
these rods will be to hold the frame parallel and not allow the sides to spread out and drop the slats out. check for nuts if threaded or if the ends are bent then look for holes in the top of the frames
3answers
What is a platform bed?
A platform bed is a bed that does not require a boxspring. Platform only refers to the portion of the frame that the mattress sits upon and does not necessarily mean that it has storage space underneath. The frame will have more supporting slats or a solid platform the mattress to set upon.
Aug 19, 2012 • Furniture
Are there any recalls on evenflow juvenile beds
I didn't find any direct information about evenflow beds. But they have some safety information that might be helpful. http://www.evenflo.com/
Jun 21, 2012 • Baby Gear
Mamas and Papas Murano Cot/Bed with missing Parts
I have a mamas and papas murano cotbed and there is a slat missing, does anyone know of a solution?
thanks
1helpful
2answers
Bambino Reale 312C crib conversion to double bed
I have the directions- but it is poorly written by the company...
I could scan and email I guess - if you still need them.
12helpful
6answers
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 • Baby Gear
Top Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Furniture Expert? Answer questions, earn points and help others
