Question about HP LaserJet 4050 Printer
How to change cartridge
I changed the cartridge in my HP LaserJet 4050, but the print quality is awful - I did press "yes" in the menu that asks is the cartridge new - can you help me?
  • nr1300 Dec 20, 2008
    the toner is the correct HP toner cartridge - thanks for trying!
    Genius:
  • 2,120 Answers
If it is remanufactured, it is probably bad. Move the drum cover back, there should be no toner on the drum.
Posted on Dec 20, 2008
  • Leroy Elliott
    Leroy Elliott Dec 20, 2008
    Trust me on this, it is BAD. I have seen HUNDREDS of bad HP and Remanufactured cartridges.
I have change the toner of Hp Color laserjet 2600n but when i print some thing then its print very light
check the supply status, if its good perform calibration, if not satisfied go to menu-quality-increase the density of each cartridge then check the quality,
if you are tec guy: if print quality both sides lighter, middle is normal open laser scan assm, clean reflect glass with ear buds/ smooth dry cloth/ leather cloth then check the quality ensure that not to touch any factory align settings...senior professional only perform this activity, strongly not suggested to juniors/ hobbyists..
Sep 09, 2011 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
My printer has two cartriges that are empty would that prevent it from printing ?
Yes the HP CLJ 2600n printer will stop printing when a toner cartridge registers as empty. The cartridges will have to be replaced or You could use the "overide out" option. This allows continued printing even though the supply registers as empty. Beware that diagnosing print quality problems because of toner becomes more difficult.
Overide Out
To change this go to the PRINT QUALITY menu then REPLACE SUPPLIES and change the setting from "stop at out" to "overide out".
Jun 16, 2010 | HP Color LaserJet 2600n Printer
How to trick the hp cp2025dn into thinking that the toner cartridge has been replaced
You might be able to use the "overide out" option. This allows continued printing even though the supply registers as empty. To change this go to the PRINT QUALITY menu then REPLACE SUPPLIES and change the setting from "stop at out" to "overide out".
Jun 06, 2010 | HP Laserjet Cp2025n Printer
Printer speed is erratic. Sometimes fast, sometimes very slow. How do I control?
Check your paper type settings in the printers menu and the driver on the pc.
Some types of paper settings will slow the printer down for improve print quality.
Set thepaper type to 'plain' for best result
May 02, 2010 | HP 4050: HP 4050 laserjet printer , 8MB...
Hp laser 4050 no printing from tray 2
Hi Trevor,
It seems like you have driver issue, you need to update your print driver, make sure you are using the correct one for your PC Operating System, go to HP support.
Contact me if you need further assistance.
Mar 13, 2010 | HP LaserJet 4050 Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet 1600, can I just print in black and white if all the cartridges need replacing but I just replaced the black
Cartridge Out Override can only be enabled from the printer's control panel menu.
1. From the main menu, press (Right arrow) to System setup and press (Select).
2. Press (Right arrow) to Print quality and press (Select).
3. Press (Right arrow) to Replace Supplies and press (Select).
4. Press (Right arrow) to Override out and press (Select).
5. Press (Select).
I suggest setting your printer to print "black only" in the printer properties window.
Apr 20, 2009 | HP Office Equipment & Supplies
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
Hope this works for you
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
LaserJet 6L Prints Outlook content too light
I also had the google maps print issue on my HP3030 and fixed it by setting the "Default Quality" under "Copy Setup" from the HP3030 menu to "Photo" from "Test".
That's a hardware setting on the HP 3030:
Menu/Enter > Copy Setup > Default Quality > Photo
Hope this helps.
Terry
Sep 30, 2007 | HP LaserJet 6Lxi Printer
HP LaserJet 4050 Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
