Question about Samsung SYNC SGH-A707 Cellular Phone
Line across Screen and will not boot up.
Battery was low and I forgot to charge it. It died completely. When I plugged it in the phone started to reboot, and a line was showing up on the screen. I would not charge nor turn on or off. Just kept trying to reboot.
  • 20 Answers
Take it apart and unplug the screen and plug it back in then restet all settings when the phone is apart try and clean it !BE VERY CAREFULL THAT YOU DONT BREAK ANYTHING ELSE ! dont do this if you dont have 1 single clue what you doing take it to the shops and get it fixed for £10-£15-£20
Posted on Dec 31, 2008
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Hi, i have a blackberry bold 9000, i went out of town for a day and forgot my charger at home and my phone was running low on battery, later that day it died. When i got home to charge it i would show the...
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
Sep 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
My Blackberry Pearl 8100 has not been used for 3 months. Now I need it again. When I plug the charger in a battery symbol with a red line through it appears on th escreen an dteh handset will not turn on.
let it charge for a while its completely drain blackberry's barley ever completely die so when the do they can't even turn on for a while after 20 minutes at most you should see it booting up(white screen with hour glass)
Apr 01, 2011 | RIM BlackBerry Pearl 8100 Smartphone
Pantech C810/Duo Power Problem
YOU MIGHT WANT TO REPLACE THE BATTERY THE LIFE MAY BE GONE CAUSING IT TO NO LONGER CHARGE
Aug 31, 2009 | Pantech Duo Smartphone
I have a similar problem.
Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
Just hold down the "end call" key for a minute and see.
This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
Aug 10, 2009 | LG Vu CU920 Cellular Phone
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
LG VX8700 won't stay charged...
I had the same problem with mine... I found that you must let the battery completely drain out; I was continuously jumping to charge my phone when it was down to one bar, and realized that upon doing this, the battery never fully retains its charge for as long as it will if you let it die out (blank screen; completely off).
I did this twice, and have not had a problem since.
Hope that helps!
Christina
Nov 25, 2008 | LG VX-8700 Cellular Phone
Phone dies quickly after charging
It would be helpful to know just how quickly the battery is going flat, and I'm assuming there's no history of the phone having been damaged, but... Try swapping the battery for one from a friend's phone. If that cures the problem, you need to buy a new battery (they don't last forever). Otherwise, try charging the battery fully in a friend's phone using their charger, then see how long it lasts. If this lasts much longer, the problem is that the phone/charger combination isn't charging the battery properly. Mix and match chargers and handsets (mark which are yours before you start, or you will get mixed up) to identify where the problem lies. If the battery isn't old and tired, and the phone is charging it properly, then the problem must be that the phone is drawing excessive current. This could be because you've got it set up to do some power-hungry thing (backlight continuously on, playing MP3s or FM, promiscuously Bluetoothing or IR communicating, etc). Shut down all the functions you don't actually need at the time and see if that makes any different. Once you've eliminated all those, you're left with the liklihood that the phone has a fault which is making it draw excess current. Not good news, but at least you've eliminated all the other possibilities. A.
Jul 25, 2007 | Motorola Mobility RAZR V3
Samsung SYNC SGH-A707 Cellular Phone Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
