Question about Sony VAIO VGN-AR630E Notebook
I have vaio Ar630e and i want to change raid configuration to 0
Difference between RAID 0 & RAID 5
Here are a couple of sites that explain the different configurations of RAID. The You Tube explanation is more detailed and helps to understand the various configurations.
RAID 0 RAID 1 RAID 5 RAID 10 Explained with Diagrams
What is RAID 0 1 2 3 4 5 6 and 10 1 0
Jan 07, 2015 | Computers & Internet
I want ot know that how can i configured hardware raid on ibm server x3400 m3 plz help me
The RAID configuration depends upon how many hard drives you have (same size and make) and which RAID level configuration your want ie. RAID 0, ot RAID 5 or a combination of RAID 0 and 1 etc.
For further RAID information, check out these WEB sites.
http://codebetter.com/raymondlewallen/2005/06/29/information-on-raid-configurations/
http://www.hardwaresecrets.com/article/393
How the RAID is configured will depends upon your your RAID controller.
May 01, 2011 | Computers & Internet
My sony vaio mini laptop can't detect my battery... even when it is charging and stuff...
  1. Open Run window and type msconfig
  2. On the System Configuration Utility window, please click the "Startup"tab
  3. Search for the "ISBmgr"
  4. Remove the check mark next to it.
  5. Then restart the Computer.
Hope this helps....
Jul 25, 2010 | Sony VAIO VGN-AR630E Notebook
Motherboard upgrade - Sony Vaio VGC-RB62G - RAID 0 issue
Why don't you try to get your main drive running before getting into Raid Configurations. Set your single drive to Master and run setup telling it you have one drive. Once you are satisfied that it is not some other fluky error, put in the other drive and I believe if SATA you don't even have to worry about Master Slave. Go about your boot and go into setup again. Hopefully all is good with the world and all that has to be done is fix up BIOS. No matter what, there is never an " out of the box " clean system. Make sure you plug your cables in correctly. I assume you're running EIDE. You'll get it.
Apr 18, 2010 | Sony VAIO VGC-RB62G PC Desktop
Webcam in vaio vgn-ar630e not work
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
Jun 03, 2009 | Sony VAIO VGN-AR630E Notebook
VAIO VGN-AR630E Drivers for Vista Ultimate
Vista Home premium drivers will work perfectly with Windows Vista Ultimate. When installing Vaio event service and Vaio Control center make sure that you run setup file as administrator. Right-click the setup file and select option "run as administrator". By reinstalling utilities this way they will work perfectly well
May 17, 2009 | Sony VAIO VGN-AR630E Notebook
How to change an LCD for a Sony Vaio VGN-AR630E
these videos might help u
http://www.youtube.com/watch?v=Fa332DImPSo
http://www.youtube.com/watch?v=2hc7rZ0iL-I&feature=related
http://www.youtube.com/watch?v=Hkue147YDvM&feature=related
pls rate me FIXYA for help if u like
Mar 25, 2009 | Sony VAIO VGN-AR630E Notebook
Setup raid configuration
Just keep pressing F2 on startup to go to bios. In bios go to advanced screen and highlight "show raid" option. Hit enter and highlight show raid. Then save changes and exit. Press Ctrl + I when booting and you will open raid configuration utility. Make sure you backup all your files and create RDVDs before making any changes to raid.After pressing ctrl+i you will get raid configration utility. From there "delete raid" -> create new raid volume and select raid type as raid 0. Then boot from RDVDs and install operating system.Let me know if there is any trouble with that
Dec 19, 2008 | Sony VAIO VGN-AR630E Notebook
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Nov 17, 2008 | Computers & Internet
Sony VAIO VGN-AR630E Notebook Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
