Hi! I have the same problem with panasonic!
Hi! i think I have the same problem with panasonic, I have PT - 53WX42F projection TV and when I turn it on it works for 3-4 seconds then shuts down and blinks 3 times and then in 4-5 seconds blinks one more time and that's all If I press power button again I cant do anything untill I unplug the wire from the power and then it repeats. I got this TV from my friend and noticed that he replaced STK 392-110 on the A-Board and I saw 2-3 shortcuts on the board while he was replacing them so maybe I think it is some automatic guard been worked so maybe I need to replace them (STK392-110 2 pcs) again? How did you fix your problem if you did and what was the reason? I would very appreciate your help to me ! Thank you ! 407 285 33 55 autocars4u@aim.com :)
MikeNJ1964
  • 398 Answers
SOURCE: Convergence IC
Yes, you can, but the -010 is the weakest IC and may not last long. I always use the -020 IC and never have problems.
Posted on Sep 04, 2007
SOURCE: TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Posted on Oct 31, 2007
SOURCE: NO PICTURE, NO SOUND, TV TURNS ON THEN TURNS OFF
STOP THE PRESS!! I FIXED MY TV for a whopping $26.
I took a wild shot and purchased two STK392-110 convergence amplifiers from http://www.electronix.com/. They ship fast, placed my order on Tuesday evening after coming here and placing my comment. To my suprise the parts were in my mailbox on Friday. The parts were actually $12 but I also picked up a iron and a solder sucker.
So rarewish4us, If you're in the South Florida area I'd be more than happy to take that "JUNK" off your hands. LOL
If I were you, I'd give it a shot before you junk it.
Good luck,
Howie
Posted on Feb 09, 2008
experttv
  • 203 Answers
SOURCE: Can't power up
The buzzing noise you are hearing is most likely the ballast fire, this is good. You most likely have a bad lamp which is the best case for you. I would recommend pulling the lamp out and looking at it to see if its physically shattered or not.
The instructions for pulling the lamp can be found in your owners manual. If you do not have this anymore just look on the sides or the back of the tv for a small door with a screw or 2 in it. take those screws out and the door should come off, then take the screw(s) out of the lamp and pull it out. if you see glass rolling around inside you will need a new lamp. Let me know and I will help you find a good one at a good price.
Tim Nolan
Posted on Sep 12, 2008
video-tek
  • 150 Answers
SOURCE: removing STK-392-110 chip
Hi, they overheated and are really stuck to the heatsink compound you will have to use a flat blade screwdriver and a hammer and tap them until they break loose, be SURE to remove the old white heatsink compound before you apply the new compound to the new stk`s, you did purchase a tube of heatsink compound for the new stk`s right? No compound = cooked stk`s in 6 months, good luck, video-tek
Posted on Feb 08, 2009
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f no sound
Pls go to the audio menu with the panasonic remote and be sure the speakers are on........you may also want to un plug and plug back after ten min to reset the tv. You may want to reset your cable box the same way
Jun 02, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F does not turn on, gives single flash code
my tv had the same problem and the B+140 was low. When I measured it, it was 89volts unfortunatly led me to the Flyback tra$former. after alot of troubleshooting work, I realized that the primary is short circuited. Also the horizontal output xsitor heats up alot on start up, thankfully it doesn't blow :)
I've had panasonic flybacks do this before to me. I havn't replaced my Flayback yet but when I pony up the $65.00 I expect (and pray) the TV to work fine. There is an off chance that something like the splitter or the foucus block caused this failure, but I doubt it.
Jul 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Resistor
electronix.com or matelectronic.com should have that resistor. Be sure to specify flame resistant 5% tolerance that is a convergence resistor so it needs to be flameproof and install it up off the board like the origional was.
Feb 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT= 53WX42F
Does it blink three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
Dec 12, 2007 | Panasonic PT-56WX53 53" Rear Projection...
Real projection tv model# pt-53wx42f
you need to replace (2) STK392-110s some are 120s 150s up grade to 180s.Also after you replace them you will have to do complete alinement of convergence in order to do this you must have service codes.
Dec 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
