Question about Dell Inspiron 9300 Notebook
Dell Inspiron 9300 battery charging problem.
12/19/2008 After working normally for about 8 months laptop now operates perfectly with AC adapter but will not charge either the old or brand new batteries. Battery symbol came on green for a minute or so after I installed the new battery but I didn't turn on machine for a couple of hours and now the symbol is out and the machine quit's instantly when the adapter is unplugged. This problem happened lierally over night.
Any ideas,
Darrell
  • sewjlw1 May 04, 2009
    Inspiron 9100, won't charge. Works fine with adapter, new battery. Shows working on ac power, but don't think it's charging the new battery.
    Brigadier General:
  • 5,158 Answers
Darrell... read this
http://www.dellbatteryprogram.com/
Robert
Posted on Dec 19, 2008
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Dell Inspiron 9300. Problem occurs when I try to charge it. The screen says it can't determine the adapter type and the battery does not charge. I can wiggle the charger cable around at the connection to...
The same exact thing is happening to my Inspiron 9300. Did you get it repaired? After reading lots of forums, changing AC adaptors and ordering a new battery, I came to the conclusion that it is the plug on the laptop that is not working.
Nov 17, 2010 | Dell Inspiron 9300 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Computer dose not charge battery (replaced battery and same problem).. Computer works fine when pluged into DC power pack.. Computer is A Dell Inspiron 9300.
check if you are using correct Watt of ac adapter.if yes then download the latest BIOS update for your laptop. if all fails then replace the motherboard.
Oct 14, 2009 | Dell Inspiron 9300 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Battery won't charge dell inspiron 9300
either ur motherboard is shot or the port that the battery connects to on the motherboard is bad
Jun 12, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
NO POWER AT ALL
Remove the battery and unplug the AC adapter. With the AC adapter unplugged from the system, plug it into the wall, see if the power LED comes on. If it does, plug it into the system and see if it goes out. If the LED never comes on, or goes out when connected to the system, replace the AC adapter.
If the LED stays one, see if the system will power on and give any indications of power at all (Flashing Caps Lock, Scrool Lock, Num Lock LEDs) If no power indication with a good ac adapter connected, then the motherboard is the next item to replace.
Either item listed above can prevent the battery from charging. So the battery is the last item I'd replace unless the system turns on with the battery out of the system.
May 20, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 Notebook Logo
1,998 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
