Question about Kitchen Ranges
Kenmore oven won't ignite (won't ''click'' to light the pilot)
The power went out in my home. when it came back on the stove (which is a kenmore ultra bake mod# 665.72133300) came back on it had pf (for power failure) and 5ab. I looked on the internet and found out that the 5ab means Sabbath mode, and I found out how to turn that mode on and off. While that mode was on, the buttons on top of the stove were not responsive. The top of stove, the burners, worked fine, but the oven was inoperable (because the buttons that controlled the oven weren't not responding).
Now that the Sabbath mode is off, the oven is still not working.
When I attempt to bake as usual: press ''bake'' set my temperature and press ''start'', normally you would hear the oven ignite (or click while it is trying to ignite)...however now, nothing happens.
Can you help me??
IFIXALL
  • 869 Answers
SOURCE: Electronic Oven Control won't work after power failure
Replace the clock.
Posted on May 22, 2008
  • 4 Answers
SOURCE: Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Posted on Sep 17, 2008
SOURCE: Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Posted on Sep 18, 2008
SOURCE: I have a Kenmore Ultra Bake Stove, we had a power
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Posted on Feb 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
Nov 23, 2011 | Kitchen Ranges
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Jul 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Kitchen Ranges Logo
365 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
