Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Picture burned into screen
I left my dvd running and came home. this has happened before but I guess today is my lucky day. When I played the dvd I noticed a shadow image of the menu in the background. its faint but it is there. Does anyone know the solution or the estimated cost of a 50" screen? Sears does not cover the burn in problem. thanks
    Sergeant:
    Champion:
  • 326 Answers
Hello, please try with all white signal. Please apply this signal during 10 hours. Best regards, Arpi
Posted on Aug 21, 2007
SOURCE:
I played draw something 2 today correct answer to the daily guess picture (April 3,2014-correct answer is bottle) the zynga board had one extra square and a blank letter tile-which has NEVER happened...
You guys are full of s**t... why give solutions if you don't understand the problem? The problem is with the app (I run mine on an iPhone). Many users have reported it (https://www.zyngaplayersupport.com/home/draw-something-2). Only Zynga can provide the solution (and they are not typically receptive).
Apr 03, 2014 | Facebook Apps
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Disc play interrupted
I recomend that you clean the lens to see if that makes a difference.
Also you might want to look at my Tip on dealing with DVD's that jump.
Apr 05, 2010 | Mintek DVD-2580 DVD Player
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
How can I burn a CD or DVD of a "movie" I made with photos and music? I am using Microsoft Picture It Express 9. Any help would be great!
Hi!
Firs of all you need to think on in what format you having that movie in. I guess you want to play it in a ordinary dvd and and they are restricted, all dvds plays mpeg bur not all plays dvix,xvid etc
When you have decided the format you need a burning program, one of the best is Nero ( http://www.nero.co ) its not free but you can download and try it for 30 days.
Another program is cdburner ( http://www.cdburnerxp.se/ ), that oen is free, not as good as nero in my opinion..but..its free
After installing the burner program you need to select if you need a cd or a dvd disk to burn on, a cd takes 700mb, there are cd:s that takes 800mb but they are more expensive. A dvd takes 4,7gb.
Now its time to burn, start the program select the disk you going to burn on, then its just to drag and drop the moviefile you want to burn. When the movie file is in place, start burning, select the burning speed, dont burn to fast since you burning a movie, i recoemnd a speed of 15-20x speed
After burning, your done! take out the disk ans enjoy your movie!
Let me know how it goes
Good luck
Nic
PS, i asume that you have a cd/dvd burner on your pc
Mar 30, 2009 | Microsoft Picture It! Photo Premium 9.0...
Hi, I bought Bose 3 2 1 SERIES 11 Home system. but i cannot play wedding dvds on my system. All hollywood movies plays ok. I tried Verbatim DVD R & DVD-R there is no picture but the sound is there....
I would say that as with many manufacturers, the Bose 3-2-1 is meant to play Dual Layer DVDs. Since they hold data on 2 separate layers of the disc, these hold twice the amount of data than the Dvd+r or -r that you're using. When the Bose system tries to read the 2 layers and only finds one it, will not recognize the dvd. If you don't have a Dual-Layer burner and Dual Layer discs to burn to, you should upgrade your burning equipment. They're not that expensive these days. Cheers!
Nov 07, 2008 | Televison & Video
Latest version. DVD Shrink. Nero8 (Todays downloads) On two Laptops. Didn't have this problem with PC's.. Shrink working ok. Nero 8 Burning dvd's. Lap tops read /Play fine. Home dvd players to home TV...
try not to do anything or open other program while its dvd shrinking or burning....bcoz dvd shrinking and burning occupies lot of memory cache and cpu usage.
GOOD DAY
Sep 15, 2008 | Computers & Internet
DVD-RW Suddenly burning slower and playing dvd's and music with a choppy lag
This is going to be a software glitch. Start by removing and reinstalling the program or programs used for playing and burning CD/DVD's. Then uninstall the drivers for the DVD drive from the device manager and reboot. The machine will find the DVD drive and reinstall the drivers automatically. This will refreshen the drive and software, and should get you back up to speed. If you continue to have the problem, then look for any software that may be conflicting with each other, ie... two different burning programs. Two like programs can conflict at any time due to the program language, settings, or if the two are fighting for which operates the drive, so if you have multiple burning or playing programs, you may want t only use one. A common cause is when a machine comes with the program, but the owner doesn't like the user friendliness or the way it operates, and downloads another to use without removing the existing program. Don't know if this applies to you, but it's a thought.
Aug 25, 2008 | Acer Aspire 5630 Notebook
Bush television & DVD error message 'unknown disk'
Some units jusy won't play certain types of recorded DVD discs. I would transfer one to a DVD+R type and see what happens. Buy a good brand like Memorex.
Hope that helps...
Geno
Mar 24, 2008 | Computers & Internet
32" Polaroid TV/DVD combo
If it's still new or less than a year take it back or call Manufacturers
Mar 18, 2008 | Televison & Video
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
