Question about Microsoft Xbox 360 Console
Cannot connect to Xbox live because my xbox can't obtain an IP adress
    Sergeant:
  • 284 Answers
Okay check the cable of the xbox make sure its not broken or KINKED could have a broken wire somewhere make sure the wire work try the wire on a computer to see if it gets an IP.
Check the connector too, make sure none of the wire are lossen up, if so then replace the connectors or buy a new wire. make sure its Cat 5 or Cat 5E. doesnt have to be cat 6. thats overkill.
if its wireless then check if your router has WEP or WAP enabled, then you have to get the Key to get into the router, and make sure the SSID of the router is correct.
Hope this helps
Good Luck
Rate this please
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Dec 19, 2008
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
My xbox 360's connection with xbox live stopped
download the next update to a usb stick via pc and install it on your game system-I had the same problem with an update a while back and had to wait for them to create another update with the patch
Apr 07, 2010 | Microsoft Xbox 360 Console
I'm trying to connect to xbox live but when I try, it says that it cannot connect and I should test the connection. When I do, I get an error message saying that it cannot obtaine my IP adress. HELP!
hmmm it sounds like there is a problem with your modem, make sure all the modem connections are securly inplace also make sure that all the correct lights are on, if this doesnt solve the problem u might want to talk to microsoft about it
Oct 11, 2009 | Microsoft Xbox 360 Console
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Xbox 360
reserve the ip address for the xbox in the router
and do port forwarding and open the xbox ports for the reserved ip
Feb 09, 2008 | Computers & Internet
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Ip adress all messed up
is the ip adress set on DHCP?
if not, set it on that
Dec 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
