Question about EuroCave Performance 283 Wine Cellar
Inside light does not stay on Euro Cave 283
I touched something on the controll panel and now the inside light (red)only is on when the door is open. What do to keep the light on all the time?
Thanks,
Bob
  • bkatz Dec 19, 2008
    Perfect! Answer correct, fast and easy to understand. Thank you very much
    President:
  • 2,110 Answers
Only on units of a certain age. If you have the light settings to "lights ON only when door is open" there is a safety mechanism built into the cabinet to warn of fluctuating current. This is part of the power cut warning system. If the unit is sharing a spur or on a circuit with other appliances they can drain power for a moment and the cabinet thinks there may be a power cut. If you would like to remedy - change the setting to "lights OFF all the time" or "lights ON all the time". Leaving the lights on all the time is the most aesthetically pleasant. The lights are UV free and cold so it is fine to leave them on all the time. Light settings can be accessed by holding down the ( - ) button until ECL is displayed. ( + ) changes the setting.
Posted on Dec 19, 2008
  • 8,197 Answers
Here is the awnser to fix this.
Intermittent Flashing LED Lights Inside light does not stay on Euro Cave 283 - lights2.jpgOnly on units of a certain age. If you have the light settings to "lights ON only when door is open" there is a safety mechanism built into the cabinet to warn of fluctuating current. This is part of the power cut warning system. If the unit is sharing a spur or on a circuit with other appliances they can drain power for a moment and the cabinet thinks there may be a power cut. If you would like to remedy - change the setting to "lights OFF all the time" or "lights ON all the time". Leaving the lights on all the time is the most aesthetically pleasant. The lights are UV free and cold so it is fine to leave them on all the time. Light settings can be accessed by holding down the ( - ) button until ECL is displayed. ( + ) changes the setting.
Good Luck And Please Rate FixYa!
  • Jyackle5
    Jyackle5 Dec 19, 2008
    good luck
2006 325 i door locks not working driver door will lock and other doors stay open if drivers door is locked it needs to be open manually back doors were locked by hand and now wont open by remote
I had a very similar situation. Was very annoying not being able to unlock or lock doors from pannel control nor from remote.
Only driver door can be opened with manual key.
Solution: One of the 15 amp purple fuses was blown. Fuses are located inside glove compartment, the interior end has to be removed releasing the two locks.
Use a light and the red tool located on the panel to remove fuses.
Oct 14, 2010 | 2006 BMW 3 Series
My interior lights in my buick century 2000 are not working.how can I check if it needs a new fuse and if it does how do I replace it? Thanks
If the lights stay off, don't go on and off randomly, and include ceiling, glove box and door lights, it is most likely a fuse. These are located behind a plastic panel on the body that can be accessed when you open the front passenger door. The fuse descriptions should be on the inside of the panel. (There is a second fuse box under the hood inside a black box with a red handle and screw hold down). Find the appropriate fuse (interior lights or something like that) and using a fuse puller (little plastic tweezer device that grabs the fuse and makes it easy to remove) pull the fuse and hold it up to the light. If the metal strip inside is broken, melted or blackened, you need a new one of the same amp rating. There may be some extra ones on the panel, but never use a fuse with a higher rating number than the original fuse.
May 21, 2010 | 2000 Buick Century
Soap dispenser unlocks but won't open
unscrewed and opened inside of door panel. Saw that spring was out of place, fixed, and reclosed. Working now.
Oct 26, 2009 | GE Dishwashers
Open door problem
There is door sensor that will be broken during your unpacking ,its near the door that show error ,try to find it then you can remove it by unplugging the cable or repair it if you can ..
Jan 15, 2009 | Samsung CLP 300 Laser Printer
1993 lumina euro z34, light on drivers door key lock stays on ?
The only way really to get to this is to Pull the Door Panel and Check the Wiring and See if there is not a Relay Inside of the Door Panel. You will need some new Door Panel Fasteners to replace the ones that Break when you remove the Panel. You can get these at any Auto Parts Store and they don't Cost that much. Let me know what you Find!
Jan 02, 2009 | 1993 Chevrolet Lumina
Multi-Function Door Control
Take off the two wires on bad of button and touch together, If it works, buy new panel or doorbell button. If not, make a jumber with a paer-clip and touch W and R terminals. If that works, replace wiring to pushbutton. (Did it ever work? If not Red and White wires may be reversed)
Aug 19, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Door Ajar Warning Light Stays On
Our Ford Expedition & an Olds Silhouette Premier & both did the same thing. Someone online said to spray the inside door where the metal connects with the frame & sensors are there with WD-40. We did & it fixed the problem. Maybe this will work for yours.
Aug 14, 2008 | 2000 Oldsmobile Silhouette
Re-Set the control panel
if you are getting blinking lights on your console you may want to open up the door and visually look inside of the middle portion of your console and you'll observe an opening. this opening is where the latch and strike comes together to enaged power to the power board. you can take a butter knife and press the latch hooks downward. when you press the latch hooks(located on the latch then look at the front side of your console panel (at the same while holding the butter knife inside the latch keeping the latch hooks press down, press a wash cycle (normal, rinse, potspans, etc) and see if there is any more flashing. If not, then there is a bad connection with the latch.
Jun 07, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Euro cave 283 1 temp
Likely the humidity sensor has gone bad if display is wrong or the display board itself is bad if no display at all.
Nov 11, 2006 | EuroCave Performance 283 Wine Cellar
EuroCave Performance 283 Wine Cellar Logo
87 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
