Question about Samsung VP-D21i Mini DV Digital Camcorder
My batter for SamSung Camcorder VP-D21i cannot be charged
I have a SamSung VP-D21i. It has 2 batteries (large and small). I have used the Camcorder for months because of the CCD sensor and filter were broken. Last week, I gave it to the service center and they replaced new CCD and filter. The problem now is that, after coming home, I know that only the small battery can be charged (green light flash), but the large one is not (there is no flash green light to indicate charging is in process). So, are there any suggestion to solve this problem. Of course, buying a new one is not what I want to know ^.^
    Master:
  • 514 Answers
Bad battery
Posted on May 02, 2017
techman
  • 3130 Answers
SOURCE: Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Posted on Apr 14, 2006
hardrocko
  • 1476 Answers
SOURCE: battery charging
When you initially used the unit was it with the battery or not? If it was with the battery was the AC hooked up also? You need to remove the batteries from the equation to find the problem. Hook the camcorder directly to the AC unit and see what it does. Also you do not mention how you know that the AC unit has power at the lead. Checking with a DMM does not garantee it. I have seen units which have the correct voltage until you put a load on the AC adapter. At this point the AC adapter could be bad, the battery could have a memory or be bad or the input jack could have a bad solder joint. If you have a DMM and know how to use it check the AC adapter for proper output. If it checks OK you will have to assume that it does not have the problem I mentioned. I have only seen that one time. With no battery on the camcorder, plug the AC adapter in and try the unit. If it does not work you probably have a broken input jack. If you are good with tools, have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience remove the covers to expose the jack and repair the connection. This should solve your problem. If you are not capable of the repair you will need to find a good reputable repair facility to take care of this. Cost should be less than $100 US. Good luck.
Posted on Jul 25, 2006
  • 5 Answers
SOURCE: Samsung SC-D363 won't charge battery
well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
Posted on Jan 03, 2008
SOURCE: VP D21i
no display at my cam when capture image
Posted on Nov 12, 2008
ginko
  • 19396 Answers
SOURCE: I have a Samsung VP-L700 camcorder, battery
Hi.
When this happens it is usually because one of the battery contacts are broken. Repair is done disassemblying the unit, using a multimeter to find broken contact (read Ohms), and soldering back the cold solder joint (other way to say broken contact on pcb).
Here service manual.
Scroll down, enter code and choose download manual for....
You can get a quote on repair here: Repair
Posted on Aug 17, 2010
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Scf-703 vhs camcorder samsung
ineed to downlaod digital cam VP-D361 pal drives
Jun 08, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
How do i rechager battery
its to the right of the buttons when you open up the screen. pull open the plastic cover
Jun 06, 2008 | Samsung VP-DC161 DVD Camcorder
VP D21i
can i get download the required driver
Apr 30, 2008 | Samsung VP-D21i Mini DV Digital Camcorder
Samsung VP-L700 Hi-8
The majority of electronic manufacturers are aware of users making mistakes with power sources; thus they generally fit electronic devices with a special size input. A small plug will not fit into a large input and visa versa. That eliminates mistakes using various power supplies. I doubt if you fried the Samsung, but stranger things have happened from time to time. Take the 700 to your local provider and ask them to run a test. Go from there.
Jan 12, 2018 | Samsung VP-L750 Camcorder
Apr 13, 2006 | Samsung VP-W75 Camcorder
I can't turn the camcorder on!
* Be sure the battery is connected properly. * Remove and replace the battery. * Connect the power adapter and ensure the battery is fully charged. * * The battery pack may be fully exhausted and require replacement. To ensure the life of your battery, be sure to remove it each time you are finished using the camcorder.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Generic batteries possible?
Generic batteries can be used with your Samsung Camcorder, but we recommend using original Samsung parts and accessories.
Samsung VP-D21i Mini DV Digital Camcorder Logo
82 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
