Question about Belkin (F8T030) (BKNF8T030) Wireless Access Point
Wireless connection want to run a ps3 off my wireless router need to find the ip address
  • Dave Reisner May 11, 2010
    What type of wireless router is it? Do you have any other wireless deives currently connected to it?
  • 141 Answers
Rebooted the system it automatically linked up the PS3 to the network
Posted on Dec 31, 2008
  • 26 Answers
Often the default IP address is 192.168.1.1
If not, the IP address may be printed on the base of the router.
Finally ring up the manufacturer and ask.
Posted on Dec 23, 2008
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
Oct 12, 2016 | Sony Playstation 3 (PS3) Console
My PS3 can't find the IP address for my wireless router and I don't know how to enter it
possible cause is that ps3 uses an ip address leased from the wi fi router via its DHCP Server in Router. If PS3 was off for a while another computer on Wi FI network may have been assigned the IP address that the PS3 thinks it has.
Try page 29 of
http://au.playstation.com/media/2Pv7AFEC/CECH-2102B_2103B-3.20_UKANZ[EN]_vf1.pdf
on page 31 change the ip address setting to manual
set ip to 192.168.0.254 subnet mask 255.255.255.0
Now exit setup
Then go back into Setup
Change IP address setting to Auto
Why
This will renew the ip address from the DHCP server to the ps3 hopefully allocating you a fresh IP address lease .
Feb 19, 2016 | Sony Playstation 3 (PS3) Console
My router was working fine with my iphone and ipad , now it will not connect and i still have a connection with my ps3
If you reset the router and have not turned off and back on all your devices you probably have conflicting addresses. some versions of ps3 will not connect for some reason unless they have the first ip available on the router.
Turn off your wirelss on your iphone and ipad, turn off the ps3. Reboot the router when it comes back up turn on the ps3 and get a good connection, the enable wireless on your ipad or iphone and get a connection the doe the same with the other.
This will avoid conflicting addresses.
An IP address has a 24 hour lease if you reboot a router it forgets what device had whipch ip address. If you need to reboot your router you need to refresh the ip address of all your devices to avoid conflicting ip's.
In this case I suspect you ipad and iphone are attempting to use the same ip address.
Jan 29, 2013 | SMC Barricade g SMC2804WBR Wireless Router
Why won't my ps3 connect to my wireless router? An IP address is needed which it will not find, only on wired connection will it connect!?
Disconnect the LAN cable from the PS3.
The PS3 needs to be configured as follows :-
Select Network Settings - Easy - Wireless - Scan, select your wireless router, select your SSID, if it isn't displayed the type it in, select security settings, enter your router's encryption settings
Your router will issue an IP address to the PS3 and you will able to access the Internet wirelessly.
Jul 26, 2009 | Computers & Internet
I can play any game online fine, but when it comes to fifa i send my friend an invite he accepts then nothing happens it just comes up this game session is no longer active, or when i do get a game it says...
You need to either give your PS3 a static IP address and then put that IP in DMZ in your router, or you need to open up the ports it tells you in the Fifa 09 manual.
To put your PS3 into a DMZ (To be done on the PS3 Console)
Firstly, you will need to assign your PS3 a static internal Ip address. This means that everytime your PS3 connects or "talks" to your router, the router will assign it a different internal IP address. These IP addresses typically run in series. So for example, if your PS3 is the second device communicating with your router, then it will be assigned an ip address of 192.168.1.3. However, if you choose to use your PS3 without the computer being on, the assigned IP address your PS3 has will be 192.168.1.2. As this is different, and obviously will change, it would be stupid setting a DMZ up on one of the above Ip addresses, unless your PS3 was the only device that would ALWAYS connect using that specific IP.
To make sure that your PS3 is always assigned the same internal IP address by your router, you will need to go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 Cross bar menus.
You will be presented with an option which primarily asks whether you are using a Wired or Wireless connection. Obviously, you will choose the option which refers to you. If choosing the Wireless option you will need to input the security details in use on your router *If you are not currently using wireless security, i strongly reccommend you do so ASAP*
Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
This will display a page where customisable IP Addresses are available to be selected.
IP Address - This will need to have the Static IP address in it. Personally, i use 192.168.1.100. I use this because it is extremely unlikely my Router will ever automatically assign this IP Address to a device, as i will never have 99 other devices connected to the same system.
Subnet Mask - Is always set to 255.255.255.0
Default Router - Is the internal IP Address of your router.
To get the exact ip of your router you should go to
Start
Run
cmd [Hit Enter]
Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
Primary DNS - Same IP Address as "Default Router"
Secondary DNS - Same IP Address as "Default Router"
After entering all of these IP Addresses, you will now click "Enter" or hit the "right" button on the D-Pad. This will take you to a screen which says "MTU" at the top. My setup has this as Automatic, solely because i haven't a clue what MTU actually means or does.This won't affect your ability to set up a DMZ.
The next steps are very simple. You do not want to use a proxy server unless you connect to the internet using one, however i can be of no help there, and you should enable UPnP if your router supports it.
To put your PS3 into a DMZ (To be done on the PC)
Now head over to your PC, and load up your internet browser. In the Address Bar, type the IP Address of your router (the one you found using the Command Prompt earlier)
This will take you to your Router Configuration Page.
Every router interface differs from an other, and depending on what router firmware update you last installed, router interfaces can differ, even on the same model routers. This means that you will need to search the router config page yourself. You are looking for any mention of "DMZ" or "DMZ Host"
When you have found this, it will ask you generally to input the IP Address of your DMZ Host, which is just the static IP address you assigned to your PS3 earlier, my example was 192.168.1.100, so we'll stick with that. Then click "apply" or similar.
You should then turn off everything running on your home network. PS3, PC, Router etc. This is solely to make sure that the changes are applied as soon as possible.
This should fix all of the problems as listed earlier in this guide, and probably some other issues
May 19, 2009 | Sony Playstation 3 (PS3) Console
WRT54G and PS3 not accessing online service
hi,
by default the router ip will be 192.168.1.245 or 192.168.10.245 or 192.168.0.245...
please check this after connecting the router to your system thru network port.
by default password will be admin without any usernames
Mar 31, 2009 | Linksys Wireless-G WRT54G Router
My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
  • Not being able to join rooms
  • Not being able to speak over your headset
  • Not being able to hear other people over their headset
  • Not being able to join private games
  • Any problems to do with connectivity to the PSN, especially if your computer will connect to the internet, but your PS3 won't.
Part 1-(On PS3)
  • Firstly, you will need to assign your PS3 a static internal IP address. Normally whenever a device connects to your router it will be assigned a different internal IP address. These are normally 192.168.1.2, 192.168.1.3, 192.168.1.4 and so on. Assigning a static one will ensure that your PS3 will get the same one every time it connects.
  • Go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 XMB. Choose whether you are using wireless or wired.
  • Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
  • This will display a page where customizable IP Addresses are available to be entered.
  • IP Address - This will need to have the Static IP address in it. Use 192.168.1.80, simply because it is unlikely that 80 other devices will be connected at the same time.
  • Subnet Mask - always set to 255.255.255.0
  • Default Router - Is the internal IP Address of your router.
    1. To get the exact ip of your router you should go to
    2. Start
    3. Run
    4. cmd [Hit Enter]
    5. Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
  • Primary DNS - Same IP Address as "Default Router"
  • Secondary DNS - Same IP Address as "Default Router"
  • Proxy � When you get to the proxy screen, select "Do not use Proxy"
  • MTU � Automatic
  • UPnP � Enabled
Part 2-(On PC)
  • In your Internet Browser, type the address of your default gateway, this will take you to your Router Configuration Page. Look for any mention of DMZ
  • When you have found this, it will ask you for the Static IP of the DMZ host. This is simply the Internal IP that you assigned your PS3. We used 192.168.1.80.
  • Finally, turn off your Router, PC and PS3 for a few minutes to ensure that the new settings are loaded. Then you're ready to go!
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Belkin (F8T030) (BKNF8T030) Wireless Access Point Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
jason
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
